Finding the Laplace Transform of f(t)=t using the definition
The Laplace transform of the function f(t) = t is derived using the definition, specifically the integral from 0 to infinity of e^(-st) * f(t) dt. The correct evaluation of this integral involves integration by parts, leading to the result of 1/s^2. The initial attempt incorrectly applied integration by parts and mismanaged limits, resulting in confusion over indeterminate forms. The final answer, confirmed by reference to standard Laplace transform tables, is 1/s^2.
  • Understanding of Laplace transforms and their definitions
  • Proficiency in integration techniques, particularly integration by parts
  • Familiarity with limits and L'Hôpital's rule
  • Knowledge of exponential functions and their behavior at infinity
  • Review the process of integration by parts in calculus
  • Study the properties and applications of Laplace transforms
  • Learn about L'Hôpital's rule and its applications in calculus
  • Explore common Laplace transform pairs and their derivations
Students studying differential equations, mathematicians focusing on transform techniques, and educators teaching calculus concepts related to Laplace transforms.
mwaso
using the definition (not the table), find the Laplace transform of f(t)=t
definition of Laplace... the integral from 0 to infinity of [(e^-st)*f(t)]dt
first I took the integral of [(e^-st)t]dt by parts and got (e^-st)(t^2)/2. I'm reasonably sure this is right cause I checked it with my TI89 :) then to evaluate it from 0 to infinity, you should be able to substitute b for infinity and take the limit as b approaches infinity. So I get the limit as b approaches infinity of (e^-sb)(b^2)/2 - (e^0)(0)/2. That second part obviously goes to 0, so we can ignore it. The first part goes to 0*infinity over 2 which isn't very helpful. However, if we move the e^-sb to the denominator, then we have the indeterminate form infinity/infinity and can utilize lohpital's (however you spell that) rule. Taking the derivative of the top and bottom yields 2b/(2se^(sb)) which is still indeterminate. Taking the derivative again gives 2/(2(s^2)*e^(sb)). This goes to zero (infinity in the denominator). However, I happen to know from my handy table of Laplace transforms that the answer I'm looking for is 1/s^2. where did I go wrong?
I think your TI89 is trying to trick you. Because the indefinite integral is definitely not correct.
No, it's wrong. Do it again, more carefully. If you still don't get the right answer, show us exactly how you integrated.
