Lowest Final Temp: Which Substance to Add?
  • Thread starter Thread starter chiurox
    Final
The problem involves determining which substance, when added to a hot water mixture, results in the lowest final temperature. The context is thermodynamics, specifically heat transfer and the effects of latent heat when ice is involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various approaches to calculating final temperatures based on different substances added to the water. There is a focus on the role of latent heat in the case of ice, with some participants questioning the setup of their equations and the specific heat values used.
The discussion is ongoing, with participants sharing their calculations and questioning each other's methods. Some guidance has been offered regarding the need to consider latent heat, and there are multiple interpretations of the results being explored.
Participants note the importance of using consistent units, such as CGS, to simplify calculations. There is also mention of potential errors in calculations, particularly regarding the specific heat of ice and the final temperature outcomes.
chiurox
An insulated container is filled with 250g of water at 90degrees Celsius. Which of the following, when added to the hot water, will result in the lowest final temperature of the mixture?
A. 10g of water at 0 degrees C
B. 125g of water at 75 degrees C
C. 15g of water at 0 degrees C
D. 5g of ice at 0 degrees C
E. 250g of water at 80 degrees C
I used (CM[dT]) + (CM[dT]) = 0
where the first part is the container's heat and the second is the supposed amount of added substance at a certain temperature.
I began plugging in numbers, starting from
A: the final temperature was 86.5
B. the final temperature was 85
C. The final temperature was 84.9
D. The final temperature was 88.23
E. The final temperature was 85.
It seems that C would be the answers, but it's just too close to B and E. Also, I think that my equation is wrong because ice has latent heat... so logically, I think that D would be the right one, because it takes heat to first melt the 5g of ice. But could anyone help me with how I should set up the equation due to the latent heat of ice?
If the final temp is t° C, then,
heat required to melt ice + heat required raise the temp of melted ice to t = heat given out by the water at 90° C to cool down to t.
You will have to consider latent heat for the part with ice.
For choice D, this is what I did:
mL + (ice's)cmdT = (water's)cmdT
(0.005*3.35*10^5) + (2000*0.005*(T-0)) = 4186*0.250*(90-T)
and I got T = 87.5 is that right?
What is the 2000 in that calculation?
I think it's the specific heat of ice.
The ice has turned to water by then though.
oh heh...
so then the final T would be 86.6 which is still not the lowest. So the answer would be C then?
That should be correct.
chiurox said:
oh heh...
I am getting 80.38 °C for D. Recheck your calculation.
I'm still getting 86.6
I did what I posted:
"(0.005*3.35*10^5) + (4186*0.005*(T-0)) = 4186*0.250*(90-T)"
I believe 80.38 is correct though. But what are you doing exactly then?
Sorry...
You got it right. I'm sorry for my wrong calculations. The ans is 86.67 °C.
[Just one point though: use CGS for this type of problems. The numbers are so much easier to deal with, provided you don't make careless mistakes like me. E.g., the equation for (D) is:
5*80 + 5(t-0) = 250(90-t).]
10K
