Solving C++ Programing Issues: Create & View Person Data
  • Context: C/C++
  • Thread starter Thread starter faust9
    C++
The discussion revolves around a C++ programming issue related to creating and viewing person data using classes. Participants are exploring problems with variable scope, data input, and output in the context of a console application.
  • One participant describes their attempt to create a program that allows users to input and view person data, noting that while age updates correctly, the name does not.
  • Another participant suggests adding debugging code in the "getdata" function to verify if the variables are being set correctly.
  • A participant mentions that the name variable seems to be scoped within the "getdata" function, while the age variable retains its class scope, leading to confusion.
  • There is a mention of the menu class that facilitates user interaction, although its implementation is not fully included in the discussion.
Participants express differing views on the cause of the issue, with some focusing on variable scope and others on debugging strategies. No consensus is reached on the exact problem or solution.
Participants note that the program uses a constructor to initialize variables, but there are concerns about how the variables are updated and retained across function calls. The discussion highlights potential issues with variable scope and the behavior of the getline function.
Readers interested in C++ programming, particularly those dealing with classes, variable scope, and console input/output operations, may find this discussion relevant.
faust9
Ok, I've been programming with C on and off for a while but I decided to take a C++ class to learn something new. We finally got to classes, and strings which are plaguing me to no end. Here's the problem, I have to write at program which creates a blank person a compile time. The software user will then enter the required information (name and age) for the fictional person. The user will then have the option to view the created person. The user may not view the created person until the initial data has been entered(not too worried about this part.
My problem is my program asks for the name and age but only the ag updates. Also, if I include a constructor the program won't replace the information supplied by the constructor. I'd like to set the default age to zero to act as the flag for the verification process. Anyway, here's the code:
main[/size]
Code:
#include "stdafx.h" //basic run of the mill include
#include "menu.h"   //required to create menus
#include "person.h" //header file which supplies the person class
int main()
    Menu personMaker;   //creates a new menu object.
    int selection;     //used to determine which menue item was selected
    //three menu line items created by using the menu class.
    personMaker.addItem ("Create a person");
    personMaker.addItem ("View person information");
    personMaker.addItem ("I bid thee a fond farewell");
    //loop used to allow person creations.
    do
        //menu title
        personMaker.displayMenu("David T Platt's Homework Extravaganva");
        selection= personMaker.getChoice(); //gets menu input from user.
        person hwPerson; //creates instance of person.
        //used to select which function to call
        switch (selection)
            case 1:
                hwPerson.getdata(); //calls function for daata input
                break;
            case 2:
                hwPerson.showdata(); //calls function for data output
                break;
            case 3:
                break;
      }while(selection !=3);
    return 0;
person.h[/size]
Code:
//obligatory includes
#include "stdafx.h"
class person
    private:
    int age;
    string name;
    public:
    void getdata();
    void showdata();
    person();
person.cpp[/size]
Code:
#include "stdafx.h"
#include "person.h"
person::person() : age(0), name("nonoame")
void person::getdata()
    cout << "\nHow old is this person? ";
    cin >> age;
    cout << "Please enter the name of the person you would like to create: ";
    cin.ignore(10, '\n');
    getline(cin, name);
    return;
void person::showdata()
    /*if (age==0)
          cout << "Sorry please enter the information prior to viewing it:";
          return;
    cout << name << " is " << age;
    return;
I commented out the verification portion. It should work (shouldn't it?).
stdafx.h[/size]
Code:
#include <iostream>
#include <tchar.h>
#include <string>
#include <conio.h>
using namespace std;
I have a menu class that works so I'm not going to post that code.
I think my problem with the name portion is with the getline(cin, name) function. Am I using it correctly? It's new to me, so I'm probably way out in left field.
here's th output:
Code:
                        1)  Create a person
                        2)  View person information
                        3)  I bid thee a fond farewell
                        Enter Choice: 1
How old is this person? 25
Please enter the name of the person you would like to create: monty python
                        1)  Create a person
                        Enter Choice: 2
nonoame is 0
                        1)  Create a person
                        Enter Choice:
Notice how the age didn't update not the name either. I'm using gcc, mingw on my wifes XP box because the class I'm taking requires win32 console apps.
Thanks for any help BTW.
Technology news on Phys.org
(The first thing I might do is to put debugging code in the "getdata" function, just to make sure the variables are being set)
There's an exercise you can sometimes do by hand to spot logic errors. You know that something is going wrong between the time you return from "getdata" and the time you call "showdata". Can you tell me everything that happens between those two functions?
Yeah, I already did that. Should've mentioned it...
Right after getline, I had:
count << name <<'\n'<< age;
and it showed the correct stuff. The name I entered. The problem seems that name is given function scope within the getdata function for some weird reason while age (if there is no constructor) is give a scope within the person class.
I don't understand the question "between the two". The only thing I have going on that I didn't include was the menu class which centers the menu in the console.
here, the menu class.cpp
Code:
#include<iostream.h>				// For cin, cout
#include<windows.h>					// For Message box stuff
#include<fstream.h>					// For ofstream operations
#include<ctype.h>					// For data validation
#include "menu.h"					// For menu declarations
// Default Constructor for menu class initalizes maxItems to zero
Menu::Menu(): maxItems(0)  { }
// Displays the menu to the screen
void Menu::displayMenu(char* title)
	cout<<"\n\t\t\t****** "<<title<<" ******\n\n";
	for (int i=1; i <= maxItems; i++)
		cout <<"\n"<<"\t\t\t"<< i << ")  "<< titles[i] << endl;
// Adds 1 new menu item
void Menu::addItem(char *menuItem)
	titles[++maxItems] = menuItem;
// Private function that validates the user response
// Note: The funky logic.  What happens is in the get function
// We pass wht the user entered, (char) to this function
// cast into a integer.  When that happens we get the ASCII
// code for the input.  Since we know that the ASCII integers
// start at 48, and we know that they are contiguios, the
// formula was designed to convert back to an integer (1-9),
int Menu::valid(int check)
	if (check > 48 && check <= maxItems+48)
		return (check - 48);
	else
		MessageBeep(MB_ICONHAND);
		MessageBox (NULL, "You typed in a wrong choice.", "Entry Error!", MB_ICONWARNING);
		cin.clear();
		cin.ignore(10, '\n'); //prevents cin from running menu off screen for
		return(-1);			  //users that type words instead of number
// Gets the choice from the user until valid.  Accepts as
// a char and type casts it to an integer for checking
// When cc is returned it will be a number [1-9]
int Menu::getChoice()
	char choiceIn;		// Variable that holds what the user entered
	int convertedChoice; // Variable that holds the converted integer
		do {
			cout << "\n\t\t\tEnter Choice: ";
			cin >> choiceIn;
			convertedChoice=valid(int(choiceIn));
		}while (convertedChoice < 0);
			return convertedChoice;
and .h
Code:
#ifndef _MENU_H
#define _MENU_H
class Menu
public:
	Menu();										// Default Constructor for menu
	void addItem(char *menuItem);				// Add Menu Item
	void displayMenu(char*);							// Display Function
	int getChoice();							// Get user Choice Function
	int getMaxItems()  {return (maxItems);}		// Returns the number of menu items
private:
	int valid(int check);						// Validates user's choice
	char *titles[10];							// Array of pointer for hold menu options
	int maxItems;								// number of menu items
#endif
Am I using getline() correctly? Do I have to change the scope of some variable(I hate these object things BTW)?
Well, let me get you started:
The program return from "getdata".
The program executs "break"
The program tests "selection != 3"
Can you carry it from here?
Ok,
Instance of menu class created
Menu items passed to menu class
do/while loop entered to allow for multiple iterations.
Title passed to menu class
personMaker menu is called with user input stored in selection variable
instance of person class created with age=0 and name"noname" as constructor arguments
switch tests selection
case 1:
getdata function is called
user is asked for age
user inputs age using cin
user asked for name
cin buffer is cleared
getline(cin, name) reads input from keyboard buffer and stores output to name
getdata returns to do/while loop
case 1 break
while test selection !=3
since selection was one, do while called again...
Ah I see says the blind man to the deaf mute... I have my class person call withing the do/while loop thus reinitializing it with each iteration.
Pretty clever...
moved offending chunk and viola! we have a working pgm!
Thanks a bunch.
So the problem was this:
being in the loop, right?
  • · Replies 30 ·
  • · Replies 25 ·
35K
