Conservation of Momentum in Elastic Collision
  • Thread starter Thread starter missnur
    Velocity
The discussion revolves around a problem involving the conservation of momentum in a perfectly elastic collision between two objects with specified masses and initial velocities. The participants are exploring the implications of the collision type on the conservation laws applicable to the scenario.
  • Participants discuss the need to apply conservation equations, specifically momentum and energy, to analyze the collision. There is a focus on understanding the definitions of velocity and the implications of a perfectly elastic collision.
The conversation is ongoing, with participants providing hints and guidance on the relevant conservation principles. There is an acknowledgment of the importance of both momentum and kinetic energy in the context of the problem, but no consensus or resolution has been reached yet.
Participants are navigating the constraints of homework guidelines, which prohibit direct answers, and are emphasizing the need for clarity on the definitions and implications of the terms used in the problem.
missnur
Hi all.
Pls help me with this question:
Two objects of mass m1=4kg and m2=2kg are moving with the same speed 1m/s towards each other before collision. Find the velocities of the 2 objects after collision if the collision is perfectly elastic.
Thank you all.
Velocities as in speeds? Remember that velocity is speed plus direction, so you can't really say if your teacher wanted 2 positive answers, or one positive and one negative answer.
Anyway, we are not allowed to give out direct answers to homework questions, but I am pretty sure that the needed formula and examples is in your textbook ;)
Good luck!
Welcome to PF!
Hi missnur! Welcome to PF! :smile:
Hint: what conservation equations do you think apply to this problem? :smile:
Hi. Hmmm..is it the conservative of momentum equation? does it mean that i will have a simultaneous equation?
Hi missnur! :smile:
Conservation of momentum is a good start.
The question tells you that the collision is perfectly elastic … questions don't say things like that unless they're important … so what does it mean? :smile:
Thank you tin tim. So when it says its perfectly elastic collision, means there is no loss of kinetic energy, right? So I am suppose to also find the conservative of energy equation?
:smile: Woohoo! :smile:
Yes … general principle … in a pure collision (no outside strings or springs etc), momentum is always conserved, and energy usually isn't conserved (unless the question somehow tells you it is)! :smile:
( … if aok now, click on "Thread Tools" to mark the thread [SOLVED] … :smile: )
  • · Replies 41 ·
  • · Replies 22 ·
  • · Replies 16 ·
