Solve Amplitude & Period Homework: Spring Constant k=74 N/m, Mass 490 g
  • Thread starter Thread starter nightshade123
    Amplitude Period
The discussion revolves around a mass-spring system where a mass of 490 g is attached to a spring with a spring constant of 74 N/m. Participants are tasked with finding the amplitude and period of the resulting motion after the mass is allowed to drop.
  • Participants explore the use of conservation of energy to relate potential and kinetic energy at different points in the motion. There are attempts to derive formulas for amplitude and period using various equations related to spring motion.
Some participants have provided guidance on using energy conservation principles, while others have suggested different approaches to calculate amplitude and period. Multiple interpretations of the problem setup are being explored, particularly regarding the definitions of variables and the setup of energy equations.
There is some confusion regarding the setup of the energy equations, particularly in defining the reference points for potential energy. Participants are also navigating the implications of using different values for displacement in their calculations.
nightshade123
A massless spring of spring constant k = 74 N/m is hanging from the ceiling. a 490 g mass is hooked onto the unstretched spring and allowed to drop.
A) Find the amplitude
B) Find the period of the resulting motion
f = 1/T
F=-kx
x(t) = Acos (omega) t
omega = sqrt( k / m )
x(t) = Acos(omega * t + phi )
omega = sqrt ( g / L )
T = 2*PI * sqrt ( L / g )
I'm lost in this chapter and have no idea where to start, i was curious if someone could help step me through this problem, would help me a ton.
Thanks!
for part b)
omega = sqrt (k / m)
freq = omega / (2PI)
T = 1/freq
i can't figure out how to find amplitude
Hi nightshade123,
Try using conservation of energy at the highest and lowest points.
at the highest and lowest points v = 0 and Potential Energy is at its max and kinetic energy is 0
i know i have this eqns
E = U + K
U = 1/2 K A^2 (cos(omega t ))^2
K = 1/2 K A^2 (sin(omega t ))^2
E = 1/2 K A^2
1/2kx + 1/2mv = 1/2kA
kx + mv = kA
v = 0
kx = kA
x=A
F = -k * x
x = - F/k
F = mg
x = (mg)/k
x = A
The amplitude is the maximum extension in the spring.
Calculate omega using omega = (k/m)^1/2.
Now calculate extension using hook's law.
Now for max extension = kx^2=mv^2
Calculate velocity.Now use v= omega*Amplitude to get amplitude.
Time period = 2pi/omega.
you don't have to do all that work A = x work it out yourself. A = .065 m thanks for the help tho
nightshade123,
kx + mv = kA
v = 0
kx = kA
x=A
This part isn't quite right. In the formula for the energies the x, v, and A have to be squared. Also, you get x=A but it doesn't tell you what either of them is. The problem is in setting up the equation like this (where x=0 at the equilibrium point).
Instead you could try setting up the equation with x=0 at the spring's unstretched point which would then explicitly include gravity in the energy equation. Letting x=0 and h=0 at the higest point, and setting energy to be conserved between the higest and lowest points gives:
[tex] \begin{align}<br /> \frac{1}{2}k x_i^2 + mgh_i &=\frac{1}{2}k x_f^2 + mgh_f\nonumber\\<br /> 0+0 &= \frac{1}{2} k x^2 + m g (-x)\nonumber<br /> \end{align}[/tex]
Solving this for the (nonzero) value of x would give the entire range of motion from highest to lowest point; the amplitude would be half of that.
nightshade123 said:
F = -k * x
x = - F/k
F = mg
x = (mg)/k
x = A
This alternative method looks good. The distance from the highest point to the equilibrium position is the amplitude and so the x value you found here equals A.
14K
