Simple pendulum and angular position
The discussion centers on deriving the angular position of a simple pendulum, specifically the equation theta(t)=Theta-max[e^(-bt/2m)], which represents a damped harmonic oscillator. Participants confirm that the motion is governed by the differential equation I(alpha) + b(omega) + g(theta)/L = 0, utilizing the small angle approximation where sin(theta) is replaced by theta. The auxiliary equation r^2I + rb + g/L = 0 is identified as essential for finding the characteristic roots necessary for deriving the general solution for theta(t). The conversation emphasizes the importance of curiosity and understanding in physics and differential equations.
  • Understanding of differential equations, specifically second-order linear equations.
  • Familiarity with the concepts of damping and harmonic motion.
  • Knowledge of the small angle approximation in pendulum motion.
  • Basic grasp of physics principles related to forces, mass, and acceleration.
  • Study the derivation of the damped harmonic oscillator equation in detail.
  • Learn how to solve auxiliary equations and find characteristic roots.
  • Explore the implications of the small angle approximation in pendulum dynamics.
  • Investigate nonlinear differential equations and their applications in physics.
Students and enthusiasts in physics, particularly those studying mechanics and differential equations, as well as educators looking to deepen their understanding of pendulum motion and its mathematical modeling.
Will
Okay, I just took the final for my first DE class! I really liked it, now I can actually know how to derive some of these equations that they just hand to you in physics and chemistry.
So anyway, there is the solution to the angular position(from vertical)of the simple pendulum; the one example we had from class(physics) was theta(t)=Theta-max[e^(-bt/2m)], but i think that the cos(omega*t+phase change) part was ommited?
So I am really interested in deriving this! So I know the motion of the pendulum is given by the diffy Q I(alpha)+b(omega)+g(theta)/L=0 where sin theta has been replace by theta because of small angle approximation, and omega and alpha are the 1st and 2nd derivatives of theta(t). So then what?. Do I solve the aux eq r^2I +rb+g/L or what? Am I on the right track?
This is for my own curiosity only, Uhh please don't tell me to "go study my book a little better" heh heh. Hell even my physics prof. would flounder trying to explain, and dudes got a doctoral degree! Like I said, we are not expected to derive these, but enquiring minds want to know! Thanks
oh god, I can't interpret your formulae in my current state
Anywayz, I think I know how to solve the problem you're talking about
If you say that the sum of forces is: Spring - Gravity - Damping you get: (saying that damping is directly proportional to speed) (X is displacement)
Net_Force = Spring_Constant*X - Weight - Damping_Constant*dX/dT
Net_Force = Mass*Acceleration
Acceleration = second derivative of X with respect to time, dX^2/d^2T
And that gives you:
Mass*dX^2/d^2T + Damping_Constant*dX/dT - Spring_Constant*X + Weight = 0
Which appears to be a linear second-order differential equation that you could solve, I'm sure
Unless you're talking about the pendulum deal where you don't say that sin(theta) =~ theta.. My Mathematics level is only a 16, unfortunately, so I can't solve that
I've heard that it can be modeled with some sort of fancy mathematical shape and fancy nonlinear differential equations-solving, but I'm afraid I can take you no farther than that
Congratulations on taking your first DE (differential equations) class and for being interested in deriving equations rather than just accepting them as given! That is a great mindset to have in the fields of physics and chemistry.
You are on the right track in terms of deriving the equation for the angular position of a simple pendulum. The equation you mentioned, theta(t)=Theta-max[e^(-bt/2m)], is the solution to the differential equation you mentioned, which is known as the "damped harmonic oscillator" equation. This equation takes into account the damping (b), the mass (m), and the length (L) of the pendulum, as well as the acceleration due to gravity (g).
In order to derive this equation, you will need to solve the auxiliary equation, which is r^2I +rb+g/L=0, as you mentioned. This will give you the characteristic equation, which will then allow you to find the roots (or solutions) for r. These solutions will then be used to find the general solution for theta(t), which can then be simplified to the form you mentioned.
It is great that you are curious and want to know more about the derivation of this equation. Keep up the good work and keep exploring and asking questions. That is the best way to learn and deepen your understanding. Good luck in your studies!
  • · Replies 32 ·
