Angular Rotation - Find Angular Velocity & Kinetic Energy Ratio
  • Thread starter Thread starter Nanuven
    Angular Rotation
The discussion focuses on calculating the angular velocity and kinetic energy ratio of a cockroach on a rotating disk. Initially, the system has an angular velocity of 0.250 rad/s. As the cockroach moves halfway to the center, the conservation of angular momentum is applied, leading to the equations involving the rotational inertia of both the disk and the cockroach. The final angular velocity and the ratio of kinetic energies are derived from these principles, emphasizing the importance of understanding rotational inertia and momentum conservation in angular motion.
  • Understanding of rotational inertia and its calculation, specifically (1/2)MR² for disks.
  • Knowledge of angular momentum conservation principles in rotating systems.
  • Familiarity with kinetic energy calculations in rotational motion.
  • Basic grasp of forces acting on objects in circular motion, including centripetal and centrifugal forces.
  • Study the derivation of angular momentum conservation equations in rotating systems.
  • Learn about the relationship between angular velocity and rotational inertia in dynamic systems.
  • Explore the concept of kinetic energy in rotational motion and how it differs from linear kinetic energy.
  • Investigate the effects of external forces on the motion of rotating bodies, including friction and gravity.
Students studying physics, particularly those focusing on rotational dynamics, as well as educators and professionals involved in mechanics and engineering applications related to angular motion.
Nanuven
[SOLVED] Angular Rotation
A cockroach of mass m lies on the rim of a uniform disk of mass 7.50 m that can rotate freely about its center like a merry-go-round. Initially the cockroach and disk rotate together with an angular velocity of 0.250 rad/s. Then the cockroach walks half way to the center of the disk.
(a) What then is the angular velocity of the cockroach-disk system?
_______ rad/s
(b) What is the ratio K/K0 of the new kinetic energy of the system to its initial kinetic energy?
______
(c) What accounts for the change in the kinetic energy?
centrifugal force
friction
cockroach does negative work on the disc
cockroach does positive work on the disc
gravity
centripetal force
Ok so Rotational Inertia of the Disk at all times would be (1/2)MR^2
Then the Rotational Inertia of the Bug would be mR initially and then (1/2)mR finally.
Since momentum is conserved Iw = Iw
Therefore,
(1/2)MR^2(.25) + (m)(R)(.25) = (1/2)MR^2(w) + (1/2)mR(w)
I have the mass of the uniform disk so I can plug that into M giving me
3.75R^2(.25) + (m)(R)(.25) = 3.75R^2(w) + (1/2)mR(w)
Now I'm lost, can anyone point me in the right direction? Thanks
Hi Nanuven,
Therefore,
The rotational inertia of the bug would be mR^2. After you have that, what would be the final value of its rotational inertia?
18K
