How Does a Cavity Inside a Charged Sphere Affect Electric Field Calculations?
The discussion revolves around the electric field calculations related to an insulating sphere with a uniform charge density and a spherical cavity at its center. The problem involves applying Gauss' Law to determine the electric field at various points both inside and outside the sphere.
  • The original poster attempts to calculate the electric field at different distances from the center of the sphere, questioning their results and seeking clarification on their calculations.
  • Some participants suggest using symbolic representations to simplify the problem and identify potential errors in the calculations.
  • There is a focus on the application of Gauss' Law and the relationship between charge density and the electric field.
Participants are actively engaging with the problem, with one confirming the correctness of the electric field being zero inside the cavity. Others are providing alternative approaches and calculations, indicating a collaborative effort to clarify the original poster's misunderstandings without reaching a definitive conclusion.
There is a mention of the complexity of the calculations involved, with participants noting the potential for errors due to the number of digits used. The discussion reflects a learning environment where assumptions and methods are being critically examined.
sonrie
An insulating sphere of radius 5.00 cm , centered at the origin, has a uniform volume charge density 3.05 uC/m^3 . There is a spherical cavity cut out of its center of radius 2.00 cm.
Well i know to use Gauss' Law:
Φ = ∫E∙dA = Q/ε
where Φ is the electric flux, E is the electric field, dA is a differential area on the closed surface S with an outward facing surface normal defining its direction, Q is the charge enclosed by the surface, and ε is the electric constant.
1.) What is the electric field at 1.43 cm ?
I found that to be zero.
2.) What is the electric field inside the spherical shell at 2.86 cm ?
Q = (4π/3)*(0.0286^3-0.0200^3)*3.05x10^-6C
The surface area integrated over is: S = 4π*0.0286^2. Hence:
E = Q/εS = (0.0286^3-0.0200^3)*3.05x10^-6/(3ε*0.028...
for surface area i get 1.03*10^-2, for Q i get 4.188*1.53*10^-5*3.05*10^-6= 1.95*10^-10
Then i divide Q/S which is 1.90*10^-12. but i keep getting it wrong. what am i doing wrong?
3.) What is the electric field outside the spherical shell at 6.75 cm ?
Q = (4π/3)*(0.0500^3-0.0200^3)*3.05x10^-6C
The surface area integrated over is: S = 4π*0.0675^2. Hence:
E = Q/εS = (0.0500^3-0.0200^3)*3.05x10^-6/(3ε*0.067...
I did the same as part two equations and i get 3.89*10^-9 which is wrong also. Help!
3. The Attempt at a Solution [/
1) is right, since there is no charge in the cavity.
For the others, I'm getting a headache reading all the digits :p It might be easier to spot a mistake if you write it out in symbols. I'll try that now.
Right,
2) After using gauss' law you should find:
[tex]E = \frac{Q}{\epsilon A}[/tex]
Q is in this case dependend on the charge density rho and the volume V:
[tex]Q = \rho V = \rho \frac{4 \pi}{3}(r^3 - {r_0}^3)[/tex] where r is 2.86 cm and r_0 is the radius of the cavity (2 cm)
[tex]E = \frac{\rho \frac{4 \pi}{3}(r^3 - {r_0}^3)}{\epsilon 4 \pi r^2} = \frac{\rho (r^3 - {r_0}^3)}{3 \epsilon r^2}[/tex]
Entering values:
[tex]r = 0.0286, r_0 = 0.02, \epsilon = 8.85 \times 10^{-12}, \rho = 3.05 \times 10^{-6}[/tex] yields:
[tex]E = 2161.9[/tex] (provided I didn't make any errors while entering the values in my calculator :p )
What should the answer be according to you?
Thanks A Bunch!
