Solve X*dX Using 74xxx Logic Circuits
  • Thread starter Thread starter hagopbul
The discussion focuses on solving the integral X*dX from x1 to x2 and from 0 to infinity using only 74xxx TTL logic circuits, specifically components such as the 7400, 7402, 7404, 7408, 7410, 7420, 7486, 7447, 7483, and 7476. Participants explore the challenge of utilizing a full adder to compute the necessary values while adhering to the constraint of using minimal additional circuits. The consensus indicates that constructing the required equation with the specified components is highly complex and may not be feasible without innovative circuit design techniques.
  • Understanding of TTL logic circuits, specifically the 74xxx series.
  • Familiarity with basic digital logic design concepts, including adders and flip-flops.
  • Knowledge of mathematical integration and its application in digital circuits.
  • Experience with circuit feedback mechanisms and counters.
  • Research the design and implementation of TTL logic circuits, focusing on the 7400 series.
  • Study the operation and application of full adders in digital circuit design.
  • Explore methods for feedback in digital counters to facilitate complex calculations.
  • Investigate alternative approaches to mathematical integration using digital logic components.
Electrical engineers, digital circuit designers, and students engaged in advanced logic circuit projects who are looking to solve complex mathematical problems using TTL logic components.
hagopbul
Solve This if you can!
how you can solve [X*dX, from x1 to x2 and from 0 to infinity ] using only this Logic circuits (or some of this circuits)[7400,7402,7404,7408,7410,7420,7486,7447,7483,7476,TTL only]
you can use an one or two extra circuits for this problem but then you have to solve this one time with the extra circuits and one without the extra circuits
you can use only 74xxx Logic circuits (TTL)
Q(7400)=A- * B-,Q(7402)=(A+B)-,Q(7404)=A-,Q(7486)=A*B,Q(7447)=(BCD to 7-seg)
Q(7483)=(Full adder),Q(7476)=(j-K F.F.)
I was trying to use the full adder to solve this BUT the Full Adder will help you to add x1,x1+1,x1+2,x1+3,….,x2 if you use the proper counter(for X^2/2 , {I was trying to use
3 F.F. ) BUT how you can feed back the info into the counter then to the full adder ...then ...I realize that this is nonsense
And how should I build the equation in the 1st place it is next to impossible if you want to use only the circuits shown above :confused:
the {lab man:rolleyes:} said to me Solve this if you can!
what i find that if i use some liner ways But if you use this way you can NOT form the equastion
19K
