Thread Closed
Vertical spring - elevator question
Share Thread Thread Tools
Apr22-08, 02:18 PM   #1
A mass is attached to a spring supported from the ceiling of an elevator. We pull down on the mass and let it to vibrate. If the elevator starts to accelerate(fixed accelerate) upward,
1) How the maximum velocity changes?
2) How the amplitude changes?
3) How the total energy changes?
I think the amplitude and maximum velocity does not change. Because the acceleration doesn't change the net force but only slide down the equilibrium point. Am i right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr22-08, 02:36 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Volcano View Post
I would agree with your choice with respect to the amplitude. However, in terms of the maximum velocity, it depends on your frame of reference, what are you measuring the velocity relative to.
P.S. We have Homework Forums for all your textbook questions.
Apr22-08, 02:40 PM   #3
___
|M|
\_\
/_/
\_\
_|_|
|....| .| moving upward
|__.|
Apr22-08, 02:45 PM   #4
Recognitions:
Quote by Crazy Tosser View Post
___
|M|
\_\
/_/
\_\
_|_|
|__.|
Your diagram is wrong, the mass is hanging down from the ceiling, inside the elevator, but thanks for your contribution anyway...
Apr22-08, 03:18 PM   #5
Recognitions:
Quote by Hootenanny View Post
Edit: It wouldn't actually make any difference to the answer, but it's best not to confuse the matter
Apr22-08, 10:42 PM   #6
oops D=
__________________
[tex]
| \amalg| \cdot \cdot \cdot \cdot \mp \cdot \cdot \cdot \cdot | \amalg |
[/tex]
[tex]
| \amalg| \cdot \cdot \cdot \cdot \bigcap \cdot \cdot \cdot \cdot | \amalg |
[/tex]
[tex]
| \amalg| \cdot \cdot \cdot \cdot |M| \cdot \cdot \cdot | \amalg |
[/tex]
[tex]
| \amalg| \cdot \cdot \cdot \cdot \bigsqcup \cdot \cdot \cdot \cdot | \amalg |
[/tex]
[tex]
| \amalg| \cdot \cdot \cdot \cdot \cdot \cdot \cdot \cdot \cdot \cdot | \amalg | \Uparrow Moving Up
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
__________________
Apr23-08, 07:21 AM   #7
it is releative to elevator. But honestly i can not explain with equations. My choice is completely instinctive. By te way, it would be nice to see the pictures with post. Latex is hard for figures.
Apr23-08, 08:53 AM   #8
Recognitions:
Then you are correct, if your measuring the velocity of the mass with respect to the elevator. Obviously, if the velocity is measured relative to some other 'fixed' point outside the elevator then this will not be the case.
Apr23-08, 09:20 AM   #9
I want to understand the effects of adding force and adding mass while it is vibrate. As you are approved, additional force on motion is not change the amplitude and maximum velocity. Now I wonder, how the mass change the amplitude and max velocity?
Now there is not an elevator. The same spring and mass attached to the ceiling of a door instead of an elevator and vibrating. While the mass in bottom position, an additional mass attached to other one suddenly. What happens now? I think, as previous problem, the equilibrium point slides down. The amplitude will not change because net force was not change. But maximum velocity will reduce because period will increase and distance was not change. Am I right now?
Apr23-08, 10:31 AM   #10
Recognitions:
I agree.
I'm not sure about your reasoning, but I agree with your conclusion.
Apr23-08, 03:39 PM   #11
I mean period proportional with mass. If mass increase period will too. Now, if amplitude the same as before then the distance for quarter period is the same too. So I think, distance the same, if time increased then average velocity must reduce.
As I understood you agree with about maximum velocity reduce. But I can not calculate these. Any suggestion?
Thread Closed
Thread Tools
Similar Threads for: Vertical spring - elevator question
Thread Forum Replies
Vertical Spring Introductory Physics Homework 8
spring and elevator Introductory Physics Homework 5
Elevator and Spring question Introductory Physics Homework 2
vertical spring Introductory Physics Homework 3
spring elevator question Introductory Physics Homework 6
