Answer didnt check with back of book
  • Thread starter Thread starter betyoudidntthink
    Book
The discussion focuses on solving two physics problems related to magnetic fields. The first problem involves determining the radius of a wire carrying a uniformly distributed current, given specific magnetic field strengths at certain distances. The second problem requires calculating the magnetic field at the axis of a solenoid influenced by a nearby current-carrying wire. Key concepts include the application of Ampère's Law, specifically the integral form \oint \vec{B} \cdot \vec{dl} = \mu_0 I_{\text{enclosed}}, which is crucial for both calculations.
  • Understanding of Ampère's Law and its integral form
  • Knowledge of magnetic fields generated by current-carrying conductors
  • Familiarity with solenoids and their magnetic field characteristics
  • Basic proficiency in LaTeX for formatting equations
  • Study the application of Ampère's Law in various geometries
  • Learn how to calculate magnetic fields around solenoids and wires
  • Explore the concept of enclosed current in magnetic field calculations
  • Practice writing and formatting physics equations in LaTeX
Students in physics, educators teaching electromagnetism, and anyone looking to deepen their understanding of magnetic fields and their calculations in practical scenarios.
betyoudidntthink
hey,
I'm not getting the answer matching the back of the book for these questions, can you show me how to do it with your work?
A long wire is known to have a radius greater than 4.0 mm and to carry a current uniformly distributed over its cross section. If the magnitude of the magnetic field is 0.285 mT at a point 4.0 mm from the axis of the wire and 0.200 mT at a point 10 mm from the axis, what is the radius of the wire?
and
A long solenoid (n = 1200 turns/m, radius = 2.0 cm) has a current of a 0.30 A in its winding. A long wire carrying a current of 20 A is parallel to and 1.0 cm from the axis of the solenoid. What is the magnitude of the resulting magnetic field at a point on the axis of the solenoid?
Can you show us what you tried and what answers you got (and how) ?
For the first question, I am assuming you calculated the magnetic field using
[tex]\int \vec{B} \vec{dl} = \mu_0 I_{\text{enclosed}}[/tex]
Did you keep in mind that, at least for the 4mm radius, the enclosed current is NOT the total current?
Finally find the right latex code, sorry :p
[tex]\oint \vec{B} \cdot \vec{dl} = \mu_0 I_{\text{enclosed}}[/tex]
(Why can't I edit my post??)
  • · Replies 23 ·
10K
