How Do You Calculate Moles and RMS Speed in Ideal Gas Problems?
  • Thread starter Thread starter Auron87
    Theory
This discussion focuses on calculating moles and root mean square (RMS) speed in ideal gas problems using the ideal gas law, specifically the equations pV = nRT and RMS speed = sqrt(3RT/Molar Mass). The user presented calculations for two scenarios involving ideal gases, including conversions from cm³ to m³ and the application of Avogadro's constant. Key corrections were made regarding the molar mass of neon and the proper use of the RMS speed formula. The discussion also addresses the derivation of pressure in ideal gases and the relationship between momentum change and gas particle velocity.
  • Understanding of the Ideal Gas Law (pV = nRT)
  • Knowledge of unit conversions (cm³ to m³)
  • Familiarity with Avogadro's constant (6.02 x 10²³)
  • Basic principles of kinetic theory related to RMS speed
  • Study the derivation of the RMS speed formula from kinetic theory.
  • Learn about the implications of temperature changes on gas behavior using RMS speed calculations.
  • Explore the concept of pressure in gases and its relation to molecular motion.
  • Practice additional ideal gas law problems to reinforce understanding of moles and gas calculations.
Students studying chemistry, particularly those focusing on thermodynamics and gas laws, as well as educators looking for practical examples of ideal gas calculations.
Auron87
I have this sheet to do but I think its really hard! I've tried most of the questions but I need someone to tell me if what I've done is right or wrong and what is wrong if it is wrong because I'm not sure on a lot of it!
1. A cylinder contains 2.3 x 10^4 cm3 of an ideal gas at a pressure of 1.8 x 10^7 Pa and a temperature of 27C.
Calculate the amount, in mol, of gas in the cylinder
The main thing here I'm not too sure about is the conversion of the volume into m3. Will it be 2.3 x 10^-2m3? Because this gave me an end answer of 166 moles which seems like quite a lot..
2. Some neon-20 gas, assumed to be ideal, has a volume of 160 cm3 at a pressure of 1.2 x 10^5Pa and a temperature of 23C.
Calculate:
a) the amount of substance in mol
again not really too sure about converting to m3 but this is what I've done:
160 cm3 = 160 x 10^-6m3
pV = nRT
1.2 x 10^5 x 1.6 x 10^-4 = n x 8.31 x 296
n = 7.81 x 10^-3
b) the number of atoms of neon present
Ermm don't know if what is right but I multiplied my answer from a) by Avogadros constant (6.02 x 10^23) to get 4.7 x 10^21.
c) the mass of a neon atom
I used this moles formula here
moles = mass
Mr
mass = 7.81 x 10^-3 x 10 = 7.81 x 10^-2
d) the rms speed of the atoms
Well I guess this depends on whether my previous answers are correct but this is what I did!
pV = 1/3Nm(mean square speed)
1.2 x 10^5 x 160 x 10^-6 = 1/3 x 7.81 x 10^-2 x (mean square speed)
mean square speed = 73.8
root mean square speed = 8.59 m/s
3. Last question now!
Calculate the factor by which the rms speed of the molecules of an ideal gas will change when temperature of the gas changes from 20C to 120C.
I'm just pretty much stuck with this question!
Thanks very much for any help!
Question 1 to question 2b seem ok to me.
This is correct.
the mass of a neon atom.
moles = mass/Molar mass
Molar mass of Neon is 20, not 10
1.2 x 10^5 x 160 x 10^-6 = 1/3 x 7.81 x 10^-2 x mass x (mean square speed)
but not
Use the following formula
rms speed = sqrt (3RT/Molar Mass)
I think you should know how to derive the formula above from pV = 1/3Nm(mean square speed)
Can someone explain why the pressure due to an ideal gas in a container is given by [tex]P = \frac{1}{3}\rho<c^2>[/tex]? (rho is the density of the gas and <c^2> is the mean square speed)
I happen to have the derivation of the eqn at hand, but somehow, there is this particular step in it I didn't understand; it's the step in which they calculated the change of momentum for a single gas molecule to be 2mv. Since force exerted on container walls is given by [tex]F = \frac {\triangle p}{\triangle t}[/tex] which means the change of momentum (p) divided by the time taken for the momentum to change.
However, in the case of the gas particle, [tex]\triangle t[/tex] was taken to be [tex]\frac {2l}{v}[/tex]! (l is the length of the cuboid container, and v is velocity of the gas molecule). Why?
11K
