Why more MHz requires more cooling?
  • Thread starter Thread starter yoran
    Cooling
The discussion centers around the relationship between a processor's clock frequency and the heat it generates. Participants explore the mechanisms behind increased heat production at higher frequencies, including current flow, state transitions in logic circuits, and the role of capacitance in power consumption.
  • One participant suggests that increased clock frequency leads to more heat due to current being sent through the processor at each clock cycle, raising questions about the nature of current flow in circuits.
  • Another participant confirms that modern CPUs use CMOS logic, where current is primarily drawn during state changes, indicating that higher frequencies result in more transitions and thus more heat generation.
  • It is noted that as circuits are miniaturized, leakage current becomes significant, contributing to overall power draw, although transitions still dominate power consumption.
  • A participant mentions that some logic circuits do not see a significant increase in power consumption with clock speed, but these alternatives may not be suitable for high-speed applications.
  • Another participant introduces the concept of capacitance in CMOS transistors, explaining that the power loss associated with driving capacitors increases with frequency.
  • A follow-up question is raised about the potential for reducing power consumption by adjusting gate widths in transistors, suggesting a possible avenue for managing heat generation at higher frequencies.
Participants generally agree on the mechanisms by which increased clock frequency leads to more heat generation, though there are nuances regarding leakage current and alternative logic designs. The discussion remains open regarding the implications of adjusting transistor designs on power consumption.
Participants express uncertainty about the nature of current flow in circuits and the implications of capacitance on power loss. There is also an acknowledgment of the complexity introduced by different logic designs and their suitability for various applications.
This discussion may be of interest to those studying computer architecture, electrical engineering, and semiconductor design, particularly in relation to power management and thermal considerations in processors.
yoran
Hi,
I was wondering why a processor is producing more heat when you increase its clock frequency. My idea is that current is sent through the processor at the beginning of each clock cycle. This produces heat and after the current is gone (does it really disappear or is there always current in the circuit?), it needs some time to dissipate its heat. If the next clock signal arrives too soon, it may not have enough time to cool down so the processor is "hotter".
I don't know if this is correct because it assumes that current is available in the circuit only for short amount of times (at each clock signal). Please correct me if I'm wrong.
Thanks.
Your intuition is basically correct. Modern CPUs use a form of logic called CMOS, in which current is (ideally) only drawn during changes in the logical state. So, increasing the clock frequency means that you make more state changes per second, and so draw more current per second, and so consume more power, which translates into more heat.
That said, as circuits are miniaturized further and further, the amount of "leakage" current which is drawn at steady state increases, and so the power draw goes up. This factor is becoming more and more important in modern logic designs, although, AFAIK, the total power consumption is still dominated by the transitions.
Also, there are other forms of logic circuits where it the state transitions do not require more power than the steady state, and so the power consumption does not increase greatly with the clock speed. However, the total power drawn by such approaches tends to be much larger than CMOS, and there are other factors that makes them unsuitable for high-speed, high-complexity applications such as microprocessors.
Ok thanks for this answer. It's just what I needed to know :).
To suppliment what quadraphonics had to say:
Each gate in a mos (cmos) transistor appears as a small capacitor. With millions of them, the capacitance adds up. The power loss in driving these little caps every clock transition is p=fcv^2, proportional to the frequency.
So Phrak, if they could trim the gate widths in those transistors, they could effectively lower the power consumption at the same frequency...or increase the frequency without raising the power beyond what is already available then?
  • · Replies 19 ·
  • · Replies 31 ·
