Voltage Drop & RE in NPN Transistors
The voltage drop across the emitter in an NPN transistor is not equal to zero; it varies based on the base current. The resistor RE, located immediately after the emitter, plays a crucial role in stabilizing the transistor's operation by affecting the voltage across the collector-emitter junction. When the base current is high, the transistor conducts, leading to a minimal voltage across the collector-emitter junction, while the resistors handle most of the power supply voltage. Conversely, when the base current is low, the collector-emitter junction stops conducting, resulting in a significant voltage drop across it.
  • Understanding of NPN transistor operation
  • Knowledge of voltage drop concepts in electronic circuits
  • Familiarity with resistor functions in transistor circuits
  • Basic grasp of power supply configurations
  • Study the role of emitter resistors in transistor biasing
  • Learn about the impact of base current on transistor operation
  • Explore the relationship between collector-emitter voltage and power supply voltage
  • Investigate different configurations of NPN transistor circuits
Electronics students, circuit designers, and engineers interested in understanding NPN transistor behavior and stabilization techniques in electronic circuits.
sanado
Is the voltage drop across the emitter in an NPN transistor equal to 0?
What is the purpose of RE (found immediately after the emitter?)
I think you're picturing the collector-emitter junction, and one or more resistors in the collector and/or emitter paths, spanning the range between the positive and negative terminals of a power supply. The transistor needs to accommodate two opposite states. If the base current goes high, the transistor conducts, the collector-emitter junction doesn't have much voltage across it, and then the resistors bear most of the power supply voltage. If the base current goes low, the collector-emitter junction stops conducting and takes up a lot more of the power supply voltage, and then the resistors won't don't get the voltage. You're expecting to go back and forth between the situation big X + small Y = constant and the situation small X + big Y= constant.
11K
  • · Replies 23 ·
