| Thread Closed |
maxwell's equations |
Share Thread |
| Apr23-08, 03:03 PM | #1 |
maxwell's equations
Are Maxwell's equations thought to be exact? I realize this question is very open-ended and loosely-phrased.
| Apr23-08, 04:12 PM | #2 |
Yes they are. But keep in mind that each one of maxwell's equations inevitably contains some sort of fundamental constant (mu or epsilon usually; not to mention electric charge etc etc) which are measured quantities and therein not exact.
Does that answer your question? |
| Apr23-08, 04:13 PM | #3 |
Yes.
| Apr24-08, 12:59 AM | #4 |
maxwell's equations
They're not exactly exact. QED makes slightly different predictions from classical electromagnetism.
| Apr24-08, 02:50 AM | #5 |
Mathematically, correct hence exact. Physically, it's a good approximation and only an approximation to model phenomena. Hence not exact physically. Is anything exact physically? No.
| Apr24-08, 07:31 PM | #6 |
which constant in Maxwell's equation is measured and not defined (to an exact value)? |
| Apr24-08, 07:56 PM | #7 |
Epsilon-not.
Mu-not is defined. At least, that's what my professor said. |
| Apr24-08, 11:50 PM | #8 |
| Apr25-08, 05:53 AM | #9 |
And the magnetic constant?
| Apr25-08, 08:10 AM | #10 |
| Apr25-08, 08:28 AM | #11 |
| Apr25-08, 08:31 AM | #12 |
Pfft, technicalities. If truth be told, the error is in disguise - it's either present in the definition(s) or as a constant in whatever expression you're using. On the other hand, there is no match for the physics of two cows™. You have two communist cows. |
| Apr25-08, 09:27 AM | #13 |
| Apr25-08, 09:48 AM | #14 |
| Apr25-08, 11:05 AM | #15 |
| Apr25-08, 11:54 AM | #16 |
![]() edit Actually, it depends. If they disagree on the status of "is string a theory ?", their interaction can be very exothermic. |
| Thread Closed |
Similar discussions for: maxwell's equations
| Maxwell's Equations | Beyond the Standard Model | 19 | ||
| Maxwell's Equations | General Physics | 21 | ||
| Re: Maxwell's equations | General Physics | 0 | ||
| Maxwell's Equations | Introductory Physics Homework | 2 | ||
| Maxwell's equations | Introductory Physics Homework | 12 | ||
