Non-inverting Op-Amp Amplifier Design for Gain of 20 & Load of 1k Ohms
  • Thread starter Thread starter kayuaret
    Op-amp
The forum discussion focuses on designing a non-inverting operational amplifier (op-amp) circuit with a voltage gain of 20 and a load resistance of 1k ohms. The output voltage is calculated to be 2 sin(omega*t) Volts, derived from the formula V output = Voltage Gain * V input. The output current through the load is determined to be 2 sin(omega*t) Amperes. Additionally, the feedback resistor Rf is established as 19 times the resistor R, confirming the design parameters for the amplifier.
  • Understanding of non-inverting op-amp configurations
  • Familiarity with voltage gain calculations
  • Knowledge of Ohm's Law
  • Basic circuit analysis skills
  • Study non-inverting op-amp design principles
  • Learn about feedback resistor calculations in op-amp circuits
  • Explore the effects of load resistance on output voltage and current
  • Investigate the use of simulation tools like LTspice for op-amp circuit analysis
Electronics students, circuit designers, and engineers working on amplifier design and analysis will benefit from this discussion.
kayuaret
Design a non-inverting op-amp amplifier for a voltage gain of 20 and a load of 1k ohms. Determine the output voltage and output op-amp current if V input = 0.1 sin (omega*t) Volts.
Voltage Gain = V output/V input
Voltage Gain = 1 + Rf/R
v output = voltage gain * v input = 0.1 sin (omega*t) * 20 = 2 sin (omega*t) Volts
i load, which is the current through R load = V output/R load = 2 sin (omega*t) / 1 ohm
I also figured out from the 2nd voltage gain equation that, Rf = 19R
  • · Replies 21 ·
