Designing a Small-Scale Solar Energy System: Boiler and Turbine Considerations
The discussion revolves around the design and construction of a small-scale solar energy system, specifically focusing on the use of a tracking parabolic mirror to heat a steam boiler for driving a turbine-generator. Participants explore various aspects including boiler design, safety considerations, energy output calculations, and the overall feasibility of the project.
  • Homework-related
  • One participant expresses interest in constructing a solar energy system with a 3-foot diameter tracking parabolic mirror and seeks advice on boiler design, pressure, and turbine construction.
  • Another participant emphasizes the importance of having the pressure vessel built by a professional for safety reasons.
  • Discrepancies arise regarding the solar energy incident on Earth, with one participant stating it is about 125 W/m², while others argue it is closer to 1000 W/m², depending on various factors including atmospheric conditions.
  • Concerns are raised about the limited power output from a 3-foot mirror, which may not be sufficient for driving a steam turbine and an automatic tracking system.
  • A participant suggests using the first law of thermodynamics to calculate the pump requirements for introducing cold water into the boiler.
  • Another participant recommends obtaining ASME code books for boiler and pressure vessel requirements before proceeding with the design.
  • One participant cautions that the small size of the mirror will likely result in minimal power generation, impacting the turbine generator's capacity.
Participants express differing views on the amount of solar energy available and the feasibility of generating sufficient power with a small mirror. There is no consensus on the optimal design parameters or energy output, indicating ongoing debate and uncertainty.
Participants reference various sources for solar energy values, but the discussion reveals a lack of agreement on the correct figures and their implications for the project. The calculations and assumptions regarding energy output and system design remain unresolved.
sngtdt
I am an amateur science/engineering enthusiast (AA electrical engineering), I would like to design/build a solar energy system consisting of a small tracking parabolic mirror heating a steam boiler to drive a small turbine-generator. The mirror I am thinking 3 foot diameter and I have some idea how to go about constructing it. The questions come in on the boiler design, pressure, safety, how to pump in the cold water feed, check valving, turbine construction, cooling the steam, and many phases of constructing same. Any info on any of the above would be appreciated.
I am also an amateur, so I can't answer much of that. What I would seriously recommend, however, is that you have your pressure vessel built by a professional shop, with an appropriate relief valve provided by them. Safety always has to come first.
Well, a useful number that you will want to know is this- solar energy incident on the Earth at sea level is about 125 W/m^2. With a 3 ft diameter mirror, this means you will only have a maximum power of about 80 W to work with; that doesn't sound like a whole lot when you're wanting to drive a steam turbine and an automatic tracking system...
Actually it's closer to 1000 W/m^2. You may be thinking of a photovoltaic cell, where the low efficiency results in an output power close to what you are saying.
See the paragraph under "Solar constant" here:
http://en.wikipedia.org/wiki/Solar_radiation
Thanks for the info, I am aware the pressure vessel would need special design cosideration, as far as the area of the mirror, this would be more or less a model. If it worked, something larger could be made.
That would be the amount of power incident at the edge of Earth's atmosphere (still in space). By the time it gets through Earth's atmosphere to the ground, I think it is anywhere from 100-375 W/m^2 average. That's at sea level in North America. The number will rise as you go higher in the atmosphere or closer to the equator, and peak power will incease or decrease depending on time of day and weather conditions.
Wikipedia Solar Energy Article said:
...in North America the average insolation at ground level over an entire year (including nights and periods of cloudy weather) lies between 125 and 375 W/m² (3 to 9 kWh/m²/day).
http://simple.wikipedia.org/wiki/Solar_energy
Well no, that number is 1300 to 1400 W/m^2. According to your link.
Checked out your link. They are averaging in the time the surface is in total darkness, and cloudy weather, to get those numbers. They also factor in that a horizontal surface is not oriented at a perfect 90 degrees to the sun.
http://simple.wikipedia.org/wiki/Insolation
The 1000 W/m^2 figure is more applicable to the purpose at hand: boiling water during daylight hours, where one can aim the setup directly at the sun.
Mech_Engineer said:
... that doesn't sound like a whole lot when you're wanting to drive a steam turbine and an automatic tracking system...
The part I am afraid will use the most energy is the pump to introduce cold water into the boiler
The pump you may use you can find it by apply the formoula of the 1st low of thermodynamics.
Q= m . C .Dt
m= mass flow rate , c= water heat coefficient 4200, dt= temperature difference between the boile imput and output.
Q= heat gain you may have.
Note: the above formula is only valid for closed systems.
Before you get to far along on a design, you should get a copy of the ASME Sections 1 and 8 for boiler and pressure vessel code requirements. Also, a copy of B31.1 Power piping would be needed. These are the American Society of Mechanical Engineers code books that govern the minimum design requirements. Also, make sure they are the 2007 editions and for Section 8 you should use Division 1 not Division 2.
sngtd, I realize that what you're building is just a model, but you probably won't get much power at all with a 3-foot mirror, so the turbine generator isn't going to be able to be big.
