Heat Loss in a House: Estimating k_eff
This discussion focuses on estimating the effective thermal conductivity (k_eff) of a house's walls and ceiling, given specific material properties and dimensions. The internal temperature is set at T_in = 20°C, while the external temperature is T_out = 0°C. The walls consist of 2 x 6-inch wooden beams with a thermal conductivity of k_wood = 0.12 W/m/K and fiberglass insulation with k_ins = 0.04 W/m/K. The calculation of k_eff requires determining the fraction (f) of the wall area that is wood, which is crucial for accurately assessing heat loss.
  • Understanding of thermal conductivity and heat transfer principles.
  • Familiarity with the properties of construction materials, specifically wood and fiberglass insulation.
  • Basic geometry and area calculations related to wall sections.
  • Knowledge of thermal resistance and effective thermal conductivity calculations.
  • Calculate the effective thermal conductivity (k_eff) using the formula k_eff = f(k_wood - k_ins) + k_ins.
  • Determine the fraction (f) of the wall area that is occupied by wood beams.
  • Explore the impact of varying wall thickness on heat loss calculations.
  • Research methods for minimizing heat loss in residential buildings.
Students studying thermodynamics, engineers involved in building design, and homeowners interested in energy efficiency and heat loss mitigation strategies.
gmarc
In this problem you will estimate the heat lost by a typical house, assuming that the temperature inside is T_in= 20degrees C and the temperature outside is T_out = 0degrees C. The walls and uppermost ceiling of a typical house are supported by 2 x 6-inch wooden beams (k_wood = 0.12 W/m /K) with fiberglass insulation (k_ins = 0.04 (W/m /K) in between. The true depth of the beams is actually 5 and 5/8 inches, but we will take the thickness of the walls and ceiling to be L_wall = 18 cm to allow for the interior and exterior covering. Assume that the house is a cube of length L = 9.0m on a side. Assume that the roof has very high conductivity, so that the air in the attic is at the same temperature as the outside air. Ignore heat loss through the ground.
The first step is to calculate k_eff, the effective thermal conductivity of the wall (or ceiling), allowing for the fact that the 2 x 6 beams are actually only 1and 5/8 wide and are spaced 16 inches center to center.
I know that k_eff = f(k_wood-k_ins)+k_ins, so I have everything except f, which is the fraction of the total wall/ceiling area in which the heat is conducted by wood. I'm having trouble finding this...
Hi gmarc,
If I'm reading the problem correctly, I would first start by focusing on a small section of a wall, perhaps starting with the right edge of one beam and ending with the right edge of the next beam. What fraction of that length (or area depending on how you are looking at it) is wood?
13K
13K
