Calculating Velocity, Range & Height of a 2kg Projectile & Counterweight
The discussion revolves around calculating the velocity, range, and maximum height of a projectile launched from a catapult, involving a 2 kg projectile and a 2 kg counterweight. The problem includes parameters such as the height from which the counterweight is dropped, the angle of launch, and gravitational acceleration.
  • The original poster attempts to clarify the parameters needed for the calculations and expresses confusion over the effects of changing gravitational acceleration on the projectile's motion. Some participants question the ambiguity in the problem specification and seek more precise details. Others suggest using conservation of energy as a potential approach, noting its limitations in accuracy.
The discussion is ongoing, with participants exploring different interpretations of the problem and the original poster seeking a working formula. There is no explicit consensus on the approach, but some guidance has been offered regarding the use of conservation of energy.
Participants note the lack of a clear formula from the original poster's teacher and the frustration stemming from the ambiguity of the problem statement. The original poster also indicates a desire to independently solve the problem once a formula is provided.
>>>SiM>>>
Example:
2 kg projectile
2 kg Counterweight
Dropped from 1m
45 Degree Angle
9.8 m/s Gravitational Acceleration
(For a catapult)
My science teacher's equation was blatantly wrong in a number of ways, so I no longer have it.
When I use his formula, not only does the velocity come out wrong, but the range is completely inaccurate, especially when the Gravitational Acceleration is altered. For example, changing the Gravitational Acceleration up or down seems to make the projectile go faster and farther, which makes no sense to me, since making it bigger should make it's distance less. Changing the Gravitational Acceleration to a negative number gives a negative answer which is wrong as well.
What I need to know is a working formula that will calculate the velocity, range, and maximum height of a projectile fired with the given five values (Mass of Projectile, Mass of Counterweight, Height the counterweight is dropped, Gravitational Acceleration, and Angle of launch). I attempted to find an answer on the internet, but then got confused trying to piece together the different formulas to fit my needs. If I have the formula, I intend to figure out the answers to all the questions myself.
He isn't available for contact so I can't ask him for a working formula myself, and I can imagine how frustrated my classmates are. My friend asked me to tell him as soon as I get an answer.
Please be more precise on your problem specification, its quite ambiguous.
I need a formula which will calculate the initial velocity of the projectile (m/s), the range of the projectile (meters) and the maximum height the projectile will reach (meters) using the Mass of the Projectile and Counterweight (kg), the height from which the counterweight is dropped (meters), the Angle it was fired (degrees), and the Gravitational Acceleration (m/s).
The only way to solve the situation with the given information is to use conservation of energy (which won't give a very accurate result).
Assume that the potential energy of the counterweight is completely converted to kinetic energy of the projectile. Groovy?
  • · Replies 38 ·
28K
  • · Replies 53 ·
