Simple differentiation question
  • Thread starter Thread starter DeanBH
    Differentiation
The discussion focuses on the differentiation of a height function for a helicopter's vertical movement, defined as y = (1/4)t^4 - 26t^2 + 96t for t between 0 and 4 seconds. The velocity is determined to be v = t^3 + 52t + 96, and acceleration is given by a = 3t^2 - 52. The key conclusion is that at t = 2, the velocity is zero, indicating a stationary point, and the sign of the acceleration at this point determines whether it is a local maximum or minimum. If the acceleration is negative, it confirms a local maximum.
  • Understanding of calculus, specifically differentiation
  • Familiarity with concepts of velocity and acceleration
  • Knowledge of stationary points in mathematical functions
  • Basic algebra for manipulating polynomial equations
  • Study the implications of stationary points in calculus
  • Learn about the second derivative test for identifying local maxima and minima
  • Explore polynomial differentiation techniques in depth
  • Investigate real-world applications of velocity and acceleration in physics
Students studying calculus, physics enthusiasts, and anyone interested in understanding motion dynamics through mathematical analysis.
DeanBH
helicopter moves vertically. Height above start point = y
height at t seconds =
y= (1/4)t^4 -26t^2 + 96t t = between 0 and 4
differentiate to find velocity = t^3 + 52t + 96
acceleration = 3t^2-52
thats part 1 of question done, easy.Verify that y has a stationary value when t = 2 determine whether it is min/max value.
i can put this into 3t^2-52t+96 and find out that it is. but how is it min/max
nevermind : i put it into acceleration and find out if acceleration is more or less than the value i got for velocity. If it's less i know that the thing will never accelerate again after this given time. so it would be a maximum. Where as if it was more than the value i got for velocity i know that the object would be able to accelerate again, which is minimum.. right?
No. For one thing you've got some scrambled formulas in your post, but assuming they are just typos, then if you did everything correctly you should have found v=0 at t=2. That's what a 'stationary' point means. Now check acceleration at t=2. What sign is it? What does that have to do with it being a min or a max?
At a stationary point the velocity is 0, so you can just compare the acceleration with 0.
if the acceleration is negative, you know there is a local maximum.
