Understanding Oblique Asymptotes in Mathematical Functions
  • Thread starter Thread starter flash
    Asymptote
The discussion revolves around the concept of oblique asymptotes in the context of the function y = x + √|x|. Participants are exploring whether this function approaches the line y = x as x approaches infinity.
  • Participants are examining the conditions under which y = x can be considered an asymptote, discussing the behavior of the function as x increases, and questioning the implications of different polynomial behaviors.
There is an ongoing exploration of the relationship between the function and its potential asymptote. Some participants are providing guidance on how to analyze the function's behavior at large values of x, while others are considering the implications of approximating the function in practical applications.
Participants are discussing the need for a more stringent requirement for asymptotes compared to general behavior of functions, indicating a nuanced understanding of mathematical definitions in the context of their applications.
flash
I am trying to draw the graph of
[tex] y = x + \sqrt{|x|}[/tex]
Can I say that as x approaches infinity, y approaches x? That would mean that the function has an oblique asymptote at the line y=x but I'm not sure.
Thanks for any help!
y=x is an asymptote if (and only if):
y-x approaches zero as x approaches infinity.
Try subtracting x from both sides of your equation, and see whether the right-hand-side expression approaches zero or not.
Alternatively, you could plug in successively larger values of x into your expression (i.e, 100, then 1000, then 10,000).
Does the difference between the value and the value of x get larger or smaller?
Eg., for x = 100:
100 + sqrt(100) = ?
This number is ____ larger than 100.
Repeat for 1000, then 10,000.
Thanks for the reply. Thats what I was thinking, the difference gets larger as x gets larger. But then I thought, when you have a function like x^2 + x, it behaves more and more like x^2 as x gets larger. This function behaves more like x as x gets larger, doesn't it?
Both statements are true, these functions "behave more like" x^2 and x, respectively. However, to be an asymptote is a more stringent requirement.
It's likely that, if encountered in a physics or engineering application, you'd be completely justified in approximating the function simply by y=x for large x.
