Prove Isometry: Exists Orthonormal Basis V w/ \|Se_j\|=1
  • Thread starter Thread starter CrazyIvan
    Isometry Proof
The discussion revolves around proving whether a linear transformation \(\mathcal{S}\) is an isometry given that there exists an orthonormal basis of \(V\) such that the norm of \(\mathcal{S} e_j\) equals 1 for each basis vector \(e_j\). The participants explore the implications of this condition in the context of linear transformations and isometries.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest that proving \(\mathcal{S}\) is normal could lead to using the Spectral Theorem, while others propose writing vectors in terms of the basis to analyze their lengths under the transformation. There is also a discussion about the interpretation of \(\mathcal{S}\) as a linear transformation from \(V\) to itself versus the dual space.
The discussion is ongoing, with participants offering different perspectives on the problem. Some express uncertainty about the correctness of their reasoning, while others encourage exploring counterexamples rather than focusing solely on proofs.
There is a noted ambiguity regarding the definition of \(\mathcal{S}\) and its properties, particularly whether it pertains to transformations within the same space or to the dual space. Additionally, participants are grappling with the implications of the given property of the transformation on the nature of isometries.
CrazyIvan
Prove or give a counterexample: if [tex]\mathcal{S} \in \mathcal{L} \left( V \right)[/tex] and there exists and orthonormal basis [tex]\left( e_{1} , \ldots , e_{n} \right)[/tex] of [tex]V[/tex] such that [tex]\left\| \mathcal{S} e_{j} \right\| = 1[/tex] for each [tex]e_{j}[/tex], then [tex]\mathcal{S}[/tex] is an isometry.
[tex]\mathcal{S}[/tex] is an isometry if
[tex]\left\| \mathcal{S} v \right\| = \left\| v \right\|[/tex]
for all [tex]v \in V[/tex].
I figure that if I can prove that [tex]\mathcal{S}[/tex] is normal, then I can use the Spectral Theorem to prove that all every basis vector is an eigenvector.
Then I can prove that the square of the absolute value of the eigenvalue for each eigenvector equals 1, and the proof comes easy after that.
But I'm getting hung up on proving if it is normal.
Thanks in advance for any help.
You don't need eigenvalues. Write v in terms of the basis: [itex]\vec{v}= a_1\vec{e_1}+ a_2\vec{e_2}+ \cdot\cdot\cdot+ a_n\vec{e_n}[/itex]. What is its length? What is Lv? What is its length?
You say [tex]\left\| \mathcal{S} e_{j} \right\| = 1[/tex]. I would have interpreted [tex]\mathcal{S} \in \mathcal{L} \left( V \right)[/tex] to mean "linear transformations from V to itself". Do you mean the dual space of V: linear transformations from V to R?
Sorry for my lack of clarity. [tex]\left\| \mathcal{S} e_{j} \right\| = 1[/tex] is a given property of the linear transformation [tex]\mathcal{S}[/tex]. So the only thing I know about [tex]\mathcal{S}[/tex] is that it's a linear transformation and it doesn't change the length of the orthonormal basis vectors.
I think I have a solution, but I'm not sure if it's the same thing you were saying:
[tex]\left\| S e_{i} \right\| = \left\| e_{i} \right\|[/tex]
[tex]\left\langle S e_{i} , S e_{i} \right\rangle = \left\langle e_{i} , e_{i} <br /> \right\rangle[/tex]
[tex]\left\langle e_{i} , S^{*} S e_{i} \right\rangle = \left\langle e_{i} , e_{i} \right\rangle[/tex]
[tex]\left\langle e_{i} , S^{*} S e_{i} - e_{i} \right\rangle = 0[/tex]
So since [tex]e_{i}[/tex] is not the zero vector,
[tex]S^{*} S e_{i} - e_{i} = 0 \ \Leftrightarrow S^{*} S e_{i} = e_{i}[/tex]
And from there, it's easy.
Does that look right?
That doesn't prove (S*)S(e_i)-e_i=0. It just shows (S*)S(e_i)-e_i is orthogonal to e_i. I would suggest you take some time out from trying to prove it and put a little more energy into looking for a counterexample.
  • · Replies 16 ·
  • · Replies 18 ·
