Thread Closed
Complicated Maxwell Boltzman Distribution Integration
Share Thread Thread Tools
Apr25-08, 02:38 PM   #1
TFM
Calculate the integral
[tex]\left v\langle\right\rangle = \int^\infty_0 v f(v) dv[/tex].
The function
[tex]f(v)[/tex]
describing the actual distribution of molecular speeds is called the Maxwell-Boltzmann distribution,
[tex]f(v) = 4\pi (\frac{m}{2\pi kT})^3^/^2 v^2 e^{-mv^2/2kt}[/tex]
(Hint: Make the change of variable
[tex] v^2 = x [/tex]
and use the tabulated integral
[tex]\int^\infty _0 x^ne^\alpha^x dx = \frac{n}{\alpha^n^+^1}[/tex]
where n is a positive integer and [tex] \alpha [/tex] is a positive constant.)
Express your answer in terms of the variables T, m, and appropriate constants.
2. Relevant equations
3. The attempt at a solution
I think I have got some way in, but I am not sure how to go from here:
firstly the:
[tex] 4\pi (\frac{m}{2\pi kT})^{3/2} [/tex]
is a constant, so can put in c for now
[tex]f(v) = (c) v^2 e^{-mv^2/2kt}[/tex]
ANd can remove from the integration
[tex]v = c \int^\infty_0 v (v^2 e^{-mv^2/2kt}) dv[/tex]
then, replace [tex]v^2[/tex] with x:
[tex]v = c \int^\infty_0 v (x e^{-mx/2kt}) dv[/tex]
and change the integration,
[tex]x = v^2, thus \frac{dx}{dv} = 2x thus dv = \frac{dx}{2v}[/tex]
Which gives:
[tex]v = c \int^\infty_0 v (x e^{-mx/2kt}) \frac{dx}{2v}[/tex]
and
[tex]v = c \int^\infty_0 (x e^{-mx/2kt}) \frac{dx}{2}[/tex]
Taking out the half:
[tex]v = c/2 \int^\infty_0 x e^{-mx/2kt} dx[/tex]
rearraniging for the tabulated integral,
[tex]\alpha = -\frac{m}{2kt}[/tex]
So:
[tex]v = c/2 \int^\infty_0 x e^{-\alpha x} dx[/tex]
Which can be integrated using tabulated given in question:
[tex]c/2 \left[\frac{1}{\alpha^2}\right][/tex]
Putting back [tex]\alpha[/tex]
[tex]c/2 \left[\frac{1}{(- \frac{m}{2kt})^2}\right][/tex]
And:
[tex]c/2 \left[\frac{1}{(- \frac{m^2}{4k^2t^2})}\right][/tex]
Which I believe can go around to:
[tex]c/2 (\frac{4k^2 t^2}{m^2})[/tex]
Putting back the c:
[tex](4\pi (\frac{m}{2\pi kT})^3^/^2)/2 (\frac{4k^2 t^2}{m^2})[/tex]
Which I think can be rarranged a bit more to give:
[tex](2\pi (\frac{m}{2\pi kT})^3^/^2) (\frac{4k^2 t^2}{m^2})[/tex]
But I am not quite sure where to go from here.
Any ideas? Does it look right?
TFM
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr25-08, 03:35 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
I am finding your solution difficult to read, partly because of errors on LaTeX and typographical errors, and partly because you are making this way too complicated. It really isn't that much work.
But here goes...
Quote by TFM View Post
This is correct.
Putting back [tex]/alpha[/tex]
Here's one of your typos: The lower case [itex]t[/itex] in the exponent should be a [itex]T[/itex], should it not?
Replace [itex]t[/itex] with [itex]T[/itex] and this is correct, too.
Start cancelling things. For instance, [itex]\frac{(2kT)^2}{(2kT)^{3/2}}=(2kT)^{1/2}[/itex].
Apr25-08, 04:22 PM   #3
TFM
Quote by Tom Mattson View Post
where did the [tex](2kt)^2[/tex] come from, and how have you removed the m and[tex]\pi[/tex] from the
[tex](\frac{m}{2\pi kT})^3^/^2[/tex] ?
TFM
Apr25-08, 05:42 PM   #4
Recognitions:
No, those are still there. I just showed you how to do one of the cancellations. Remember you are allowed to move factors around and group them together.
Apr26-08, 04:07 AM   #5
TFM
Looking at it , does this look right:
[tex]2\pi(\frac{m^3^/^2}{(2\pi kt)^3^/^2})(\frac{(2kt)^2}{m^2})[/tex]
Taking out the pi from the first fraction:
[tex](\frac{2 \pi}{\pi^3^/^2})(\frac{m^3^/^2}{(2kt)^3^/^2})(\frac{(2kt)^2}{m^2})[/tex]
Does this look okay?
TFM
Apr26-08, 07:27 AM   #6
Admin
When doing an exponential which involves an expression, put the entire expression after the ^ in parentheses { }. This groups the entire expression, e.g. e^{-mv^2/2kT} yields
[tex]e^{-mv^2/2kT}[/tex]
It's also best to follow convention and use t for time, and T for temperature.
Also, in the OP, [tex]\alpha = \frac{m}{2kT}[/tex], so that the definite integral is finite.
Then [tex]\frac{1}{\alpha^2} = \frac{4k^2T^2}{m^2}[/tex]
Apr26-08, 12:42 PM   #7
TFM
Thanks for this ^ , I never knew this before
Does this mean I got the calculations in my last post wrong?
TFM
Apr26-08, 03:02 PM   #8
TFM
[tex]2\pi(\frac{m^{3/2}}{(2\pi kt)^{3/2}})(\frac{(2kt)^2}{m^2})[/tex]
From this, I have since got:
[tex] (\frac{2 \pi}{\pi ^{3/2}})(\frac{m^{3/2}}{m^2})(\frac{(2kT)^2}{(2kT)^{3/2}}) [/tex]
Which I cancelled down to:
[tex] (\frac{2 \pi}{\pi ^{3/2}})(\frac{1}{\sqrt{m}})(\sqrt{}2kT) [/tex]
Does this look right?
TFM
Apr27-08, 08:32 AM   #9
Admin
[tex] (\frac{2 \pi}{\pi ^{3/2}})(\frac{1}{\sqrt{m}})(\sqrt{2kT}) [/tex]
TFM
Correct!
Well continuing the cancellation of pi in the last expression, one obtains
[tex] \left(\frac{2}{\pi^{1/2}}\right)\left(\frac{1}{\sqrt{m}}\right)(\sqrt{2kT}) [/tex],
Then one can bring pi and m under the square root as the denominator under the numerator 2kT,
[tex] 2 \sqrt{\frac{2kT}{\pi m}} [/tex]
which is the same as
[tex] \sqrt{\frac{8kT}{\pi m}} [/tex] which is correct.
and now that you've gone through this exercise
http://hyperphysics.phy-astr.gsu.edu...kintem.html#c3
One should also try the relationsip between mean kinetic energy and gas temperature,
or <v2>.
Apr27-08, 08:49 AM   #10
TFM
Thaks for all the Help,
TFM
Thread Closed
Thread Tools
Similar Threads for: Complicated Maxwell Boltzman Distribution Integration
Thread Forum Replies
Boltzman Distribution & Principle of a priori probablities Classical Physics 1
Partition function & Boltzman, Maxwell distri Classical Physics 4
Maxwell/Maxwell-Boltzmann Distribution Classical Physics 1
How is the maxwell-boltzman distribution comparable to canonical distribution? Advanced Physics Homework 0
