Independence of Path: Understanding Line Integrals in the xy-Plane
  • Thread starter Thread starter kasse
    Independence Path
The discussion revolves around the independence of path for a given line integral in the xy-plane, specifically examining the integral of the form Int((y2 + 2xy)dx + (x2 + 2xy)dy). Participants are exploring the conditions under which this integral is path-independent.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are considering various reasons for the path independence, including total derivatives, the curl of the vector field, and the implications of Green's and Stokes' theorems. Some are questioning the applicability of these theorems and discussing the characteristics of conservative fields.
The discussion is active, with multiple interpretations being explored regarding the independence of path. Some participants have provided guidance on checking the conditions for conservative fields and relating the problem to known theorems, while others express uncertainty about the applicability of Stokes' theorem in this context.
There is mention of varying course content affecting the understanding of the problem, as well as the need to clarify the definitions and conditions related to conservative fields and theorems applicable to line integrals.
kasse
Why is the given line integral independent of path in the entire xy-plane?
Int((y2 + 2xy)dx + (x2 + 2xy)dy)[/i]
Because it's a total derivative?? Because regarded as a line integral of a vector field it's curl is zero?? Because it's the contour integral of an analytic function?? Take your pick, depending on the course you are in. They are all the same. Show one of them.
If you know Greens or Stokes theorem, you should check them out for this -- that is perhaps the quickest way to see the answer by just looking at the integral.
If not, then have you talked about conservative fields? You should check out what the necessary conditions are for a conservative field and apply it here.
Stoke's theorem clearly does not apply here. Green's theorem does but is far more general than needed here. As Dick said, your answer will depend upon the course, but the simplest thing to do is show that (y2 + 2xy)y= 2y+ 2x= (x2 + 2xy)x and so this is, as Dick said, a "total derivative" (I would say an "exact differential"): there exist a function F(x,y) having this as its differential. The integral along any curve is just the difference of F evaluated at the two endpoints.
Stokes would deffinitely work. You just set your vector field equal to F=<y^2 + 2xy, x2 + 2xy,0> and then he has the integral F.dr. You use stokes theorem and get the same answer as greens would give you. But maybe I am missing something because I've only recently started studying Stokes.
Stoke's theorem refers, in general, to an integration over a curved surface in R3. Green's theorem refers to an integeration over an area of R2. If you take your surface to be the xy-plane, then Stoke's theorem reduces to Green's theorem.
  • · Replies 32 ·
  • · Replies 21 ·
