Confused about Polarity of Induced EMF (Lenz Law)
The discussion revolves around the polarity of induced electromotive force (EMF) as described by Faraday's Law and Lenz's Law. Participants explore the relationship between the orientation of the surface element (dS) and the resulting EMF, as well as the implications of Lenz's Law in determining the direction of induced currents and magnetic fields.
  • One participant expresses confusion regarding the arbitrary nature of the sign convention for EMF and its dependence on the assumed direction for dS.
  • Another participant challenges the correctness of the initial equation provided, referencing the relationship between induced EMF and the rate of change of magnetic flux.
  • A participant explains that the orientation of the surface element determines the direction of the line integral, affecting the resulting EMF polarity.
  • Multiple participants discuss Lenz's Law, with one suggesting it is a component of Faraday's Law that helps determine the direction of induced EMF, while another critiques the presentation of Lenz's Law in their textbook.
  • There is a suggestion that Lenz's Law can be broken down into multiple components, with skepticism about whether some aspects are independent of Faraday's Law.
Participants do not reach a consensus on the interpretation of Lenz's Law or the relationship between the various components of Faraday's Law. There are competing views on the clarity and independence of these laws as presented in textbooks.
Participants express uncertainty regarding the definitions and implications of terms like "chirility" and the orientation of surface elements, which may affect their understanding of the laws involved.
nyxynyx
Hello, I am currently working through Faraday's Law and I am confused when my two textbooks don't explain how they set the polarity of [tex]V_{emf}[/tex], particularly when they say "the sign convention for [tex]V_{emf}[/tex] is arbitrary in that it depends on the assumed direction for dS". How is the polarity related to dS?
The formula I am using is [tex]v_{emf} = - \int_c \vec{B}\cdot d\vec{S} = \oint_c \vec{E}\cdot d\vec{L}[/tex]
Here's a diagram that you can try explaining it from.
Thanks!
Science news on Phys.org
For one thing, that equation is incorrect. http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/farlaw.html" states how the induced EMF relates to the rate of change of the magnetic flux ([itex]\Phi[/itex]):
[tex]{EMF} = - d\Phi/dt[/tex]
The polarity of the EMF (the meaning of the minus sign) is given by http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/farlaw.html#c2".
Oops i left out the time differential. Can anyone explain what my textbook is saying?
What they are trying to tell you is that the orientation of the surface determines the direction of the line integral. Imagine a circle (which we'll be finding the flux through) drawn on the x-y plane at z = 0 . If we arbitrarily choose +z as the direction of the surface element (dS) that means the line integral will go counter-clockwise when viewed from the +z axis looking down. And if we choose the opposite orientation, the line integral will go clockwise when viewed from +z.
So if we've chosen an orientation such that the line integral goes clockwise, a negative EMF means that the EMF is oriented counter-clockwise.
Make sense?
Doc Al. Lenz's Law in my text reads more like a hastily scribbled perscription than single law. First there's a given flux that yields the chirility of the EMF. Then an (implied) inducted current. Then the induced current is said to product a magnetic field that opposes the induced flux.
Lenz's law can be considered part of Faraday's law--the part that helps you determine the direction of the induced EMF (the negative sign in Faraday's law). It's a consequence of energy conservation. Not sure what you mean by calling it "hastily scribbled". :confused:
Well, perhaps "hasilt scribbled" is overly critical. But what I'm given are really three laws rather than one. If I break them down into my own numbering, Lenz1 determines the direction of EMF as you say.
The secone one (Lenz2) says that there could be a current as a result of the EMF, which seems to be a already obtained from Lorentz law.
Lenz3 says that an induced current generates an additional magnetic flux in opposition to the impressed flux. It's the result of two handedness operations, so I don't think it is really dependent upon Lenz1 anymore; the induced flux acts to impose the impressed flux no matter what handedness you give the coordinate system. Though my text later presents self inductance as a result of Lenz3, I'm skeptical that Lenz3 is an independent axiom that isn't inherent in Faraday's Law.
