Where Did I Go Wrong in Calculating Mixed Partial Derivatives?
The discussion revolves around finding the second partial derivatives of the function z = x/(x+y). Participants are attempting to compute the mixed partial derivatives d^2f/dydx and d^2f/dxdy, but are encountering discrepancies in their results.
  • Mixed
  • Participants are sharing their attempts at calculating the derivatives using both product and quotient rules. Some express confusion over the results not matching and question the application of Clairaut's theorem regarding the equality of mixed partial derivatives.
There is an ongoing exploration of the calculations, with some participants suggesting simplifications and others pointing out potential errors in the differentiation process. A few participants have noted that their results contain different variables, indicating a lack of agreement on the correctness of their answers.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is also a mention of a specific expected answer from a textbook that is not being matched.
fk378
Find the second partial derivatives.
z= x/(x+y)
I solved the correct df/dx, d^2f/dx^2, df/dy, and d^2f/dy^2, however I can't seem to get the correct answer for d^2f/dydx and d^2f/dxdy.
My df/dx is y/(x+y)^2 which I changed to y((x+y)^-2)
Differentiating with respect to y, using the product rule: (1)(x+y)^-2 + y(-2)((x+y)^-3) = (x+y)^-2 - 2y((x+y)^-3)
My df/dy is -x((x+y)^-2)
Differentiating with respect to x, using the product rule: (-1)(x+y)^-2 + (-x)(-2)((x+y)^-3) = -(x+y)^-2 + 2x((x+y)^-3)
I know they aren't right b/c 1) they don't equal each other (Clairaut's Thm.) and 2) it doesn't match the book's answer =)
Can anyone catch the mistake I'm making? Thank you.
I think you're right. You seem to have done everything ok. Just try to simplifiy both result solving the Newton binomials. Probably everything will reduce and you'll have your right awnser.
Remember if you get tired check the trigger happy videos at tubepolis.com They're really really funny and stress reliefers.
Hm, I don't think it works out. I just tried to simplify it and I still didn't get the right answer. Also, my d^2f/dydx answer has a y variable in it, while my d^2f/dxdy answer has an x variable in it. And simplifying either expression doesn't get rid of them.
The correct answer is supposed to be (x-y)((x+y)^-3)
you can simplify df/dx to
[tex] \frac{y}{(x+y)^2}[/tex]
and you can simplify df/dy to
[tex] \frac{-x}{(x+y)^2}[/tex]
Taking d/dx on the above gives
[tex] (-1)(x+y)^{(-2)}+2x/(x+y)^3<br /> =\frac{x-y}{(x+y)^3}\;.[/tex]
You can also show that d^2f/dydx is the same
Isn't the denominator supposed to be [g(x)]^2 so why isn't the denominator (x+y)^4?
And, can you see what I did wrong when I used the product rule?
you didn't do anything wrong. df/dx and df/dy are *not* "supposed to equal each other". It is
[tex] \frac{d^2 f}{dxdy}[/tex]
which is supposed to equal
[tex] \frac{d^2 f}{dydx}[/tex]
The expression you gave for d^2f/dxdy is
[tex] -\frac{1}{(x+y)^2} + \frac{2x}{(x+y)^3}[/tex]
which can be simplified to the book's answer using algebra (multiply the first term by (x+y)/(x+y) and then the terms have the same denominators and you can add the numerators)
I can't see your latex image for some reason--it says it is invalid. Also, my answers are not the same. One has a y variable, the other has an x variable. Also there are different signs within each expression.
hmm... I don't know why you can't see the latex... maybe try reloading.
No, there is no mistake- that's what everyone is trying to tell you. Yes, If you had done this using the "quotient" rule, the denominator would have (x+ y)4. But the numerator would have a factor of (x+ y). Try it!
z= x/(x+y)
So [tex]\frac{\partial^2 f}{\partial x\partial y}= \frac{1}{(x+y)^2}+ \frac{-2y}{(x+y)^3}[/tex]
[tex]= \frac{x+ y}{(x+y)^3}+ \frac{-2y}{(x+y)^3}= \frac{x- y}{(x+y)^3}[/tex]
So [tex]\frac{\partial^2 f}{\partial y\partial x}= \frac{-1}{(x+ y)^2}+ \frac{2x}{(x+y)^3}[/tex]
[tex]= \frac{-(x+y)}{(x+y)^3}+ \frac{2x}{(x+y)^3}= \frac{x- y}{(x+y)^3}[/tex]
Looks to me like they are exactly the same!
I see it! Thank you all =)
I did not catch the multiplication of the expression by (x+y)/(x+y)
