Taylor Polynomial of Order 3 for f(x,y,z) at (0,0,0)
The discussion revolves around finding the Taylor polynomial of order 3 for the function f(x,y,z) = √(e^(-x) + sin(y) + z²) at the point (0,0,0). The original poster indicates a requirement to use well-known series rather than derivatives for this calculation.
  • Exploratory, Assumption checking
  • The original poster attempts to express the function using Taylor polynomials for the components within the square root but struggles with the square root itself. Some participants question the choice of approach, suggesting the use of derivatives instead. Others inquire about the Taylor series for √x and the challenges of calculating it at x=0 due to undefined derivatives.
The discussion is ongoing, with participants exploring different methods to approach the problem. There is recognition of the constraints imposed by the requirement to use well-known series, and some guidance has been offered regarding the Taylor series expansion formula.
The original poster is constrained by the requirement to avoid direct derivative calculations, which has led to confusion regarding the application of Taylor series for the square root function.
gop
Calculate the taylor polynom of order 3 at (0,0,0) of the function with well-known series (that means I can't just take the derivatives)
[tex]f(x,y,z)=\sqrt{e^{-x}+\sin y+z^{2}}[/tex]
I wrote the functions within the square root as taylor polynomials and got
[tex]f(x,y,z)=\sqrt{1+-x+\frac{1}{2}x^{2}-\frac{1}{6}x^{3}+y-\frac{1}{6}y^{3}+z^{2}}[/tex]
But then I don't really know how to "remove" the square root. I already tried to just plug the term inside the square root in the taylor expansion of [tex]\sqrt{1+x}[/tex] but that didn't really work out very well.
Why did you do that? What not just write [itex]f(x,y,z)= (e^{-x}+ sin(y)+ z^2)^{1/2}[itex]and calculate the derivatives?[/itex][/itex]
Reference The formula for the Taylor series expansion of [itex]f(x,y,z)[/itex] about the point [itex](x_0,y_0,z_0)[/itex] is
[tex]f(x,y,z)=\sum_{n=0}^{\infty}\sum_{k=0}^{\infty}\sum_{j=0}^{\infty} \frac{\partial ^{n+k+j}f (x_0,y_0,z_0)}{\partial x^{n}\partial y^{k}\partial z^{j}} \cdot\frac{(x-x_0)^{n}}{n!} \cdot\frac{(y-y_0)^{k}}{k!}\cdot\frac{(z-z_0)^{j}}{j!}[/tex]​
Use To compute the Tayor polynomial of order 3, only write out the terms for which [itex]n+k+j\le 3[/itex].
As stated I have to use "well-known series" to arrive at the taylor polynomial; thus, I'm not allowed to just take derivatives.
Sorry, I missed reading that part!
Okay, what is the Taylor's series for [iitex]\sqrt{x}[/itex]?
I can't really calculate the taylor series at x=0 because the derivatives is then of the form 1/0 and doesn't exist. I already tried sqrt(1+x) but that didn't produce a correct result.
  • · Replies 17 ·
