| Thread Closed |
Light & Mirrors |
Share Thread |
| Apr27-08, 02:08 PM | #1 |
Light & Mirrors
1) A 24 cd point source lamp and a 73 cd point source lamp cast equal illuminances on a wall. If the 24 cd lamp is 6.3m from the wall, how far from the wall is the 73 cd lamp? Answer in units of m. 2) Two lamps illuminate a screen equally. The first lamp has an intensity of 100 cd and is 6.7m from the screen. The second lamp is 7.7 m from the screen. What is the intensity of the second lamp? Answer in units of cd. 3) Determine the minimum height of a vertical flat mirror in which a person 67 in. in height can see his full image. Answer in units of in. (Hint: draw a ray diagram) 4)A concave mirror has a focal length of 24.8cm. Determin the object position for which the resulting image is upright and 4 times the size of the object. Answer in units of cm. 2. Relevant equations Focal length= [tex]\frac{Radius}{2}[/tex] [tex]\frac{1}{focal length}[/tex] = [tex]\frac{1}{distance of object}[/tex] + [tex]\frac{1}{distance of image}[/tex] magnification = [tex]\frac{-distance of image}{distance of object}[/tex] = [tex]\frac{height of image}{height of object}[/tex] 3. The attempt at a solution My teacher told us we wouldn't need to know the equations for light intensity, so I have no idea how to solve 1&2. 3) I drew the ray diagram like it said and found the area of mirror needed to see the image. But obviously it's not to scale, and I doubt I could measure it and scale it well enough to get an accurate answer, because the system we use to turn in homework likes exact answers that are at most +/-1% off. 4)I tried using this [tex]\frac{1}{focal length}[/tex]=[tex]\frac{1}{distance of object}[/tex]+[tex]\frac{1}{distance of image}[/tex] I knew that the distance of the image was 4 times the size of the object so i substituted distance of image with 4(distance of object). Crunching the numbers I got 31, which doesn't make sense because if the object is outside the focal point of a concave mirror, then the image will appear smaller, not larger. I think I messed up because it says the size is 4 times larger, which probobly means height, not distance. But, I'm not sure what to do. |
| Apr27-08, 05:09 PM | #2 |
I found the equations for 1&2, so I don't need help with those anymore.
| Apr27-08, 05:25 PM | #3 |
Recognitions:
[tex] M = \frac{h_i}{h_o}= \frac{-q}{p} [/tex] where p is the object distance and q is the image distance. So here when you substitute you will have a minus sign (since the image is upright). |
| Apr27-08, 05:34 PM | #4 |
Light & Mirrors
Thankyou so much. I got 18.6 substituting with -4 instead of 4, which was correct. I also got the 3rd question right. So I don't need any more help now.
| Thread Closed |
Similar discussions for: Light & Mirrors
| light, lenses, and mirrors | Introductory Physics Homework | 1 | ||
| Optics (refracting light) and (mirrors) | Introductory Physics Homework | 6 | ||
| Mirrors, light and camera | General Physics | 2 | ||
| Light Reflection Through Mirrors | Introductory Physics Homework | 1 | ||
| Light, Mirrors, Lenses, immediate help required! | Introductory Physics Homework | 1 | ||
