New Reply
numbers in Ascending Order in C++
Share Thread Thread Tools
Apr28-08, 03:11 AM   #1
i have to write such a program that takes 10 integers from user and show them in ascending order.
My attempt was ---
#include<iostream.h>
#include<conio.h>
int main()
int a[10];
for(int i=0; i<10; i++) //this loop is used for getting the 10 integers from user
cin>>a[i];
...................... // here I'm stuck. I couldn't find how should i sort them. I can sort
// number using 'if..else if' statement which makes the program lengthy
// for this propblem.
getch();
return 0;
So plz help me if any one knows how to sort 10 integers so that it doesn't make the codes lengthy.
thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr28-08, 03:47 AM   #2
Why not just use qsort? Or are you required to actually write the low-level sorting algorithm directly? If so, I'd look at the Wikipedia pages on qsort and heapsort for some ideas; they have pretty good explanations and psuedocode.
Apr28-08, 04:45 AM   #3
Mentor
A bubble sort is quick and easy to code. Simple go through your list swaping adjacent numbers if they are out of order. Repeat until there are no swaps.
Apr28-08, 06:57 AM   #4
Recognitions:
Gold Membership Gold Member
If you are allowed to use the stl and the vector container, try sort().
Apr28-08, 09:00 AM   #5
thanks to all replied...Actually I'm newbie in c++. I haven't studied qsort, heapsort or vector container..
swapping technique is suitable for my level...I used it in the for loop
for(int p=0; p<9; p++)
for(int i=0; i<9; i++)
if(a[i]>a[i+1]) // comparison between two adjacent array elements
holder=a[i]; // holder holds the value temporarily
a[i]=a[i+1];
a[i+1]=holder;
Apr28-08, 10:23 AM   #6
Recognitions:
Homework Helper Homework Help
Depends what sort of class this is !
If you are supposed to write the sort then bubble sort is easiest - justify your choice over a qsort by saying that the speed difference is small for only 10numbers !
If this is a real programming class then use.
vector<int>a;
for( ....
a.push_back( input )
sort(a.begin(),a.end());
Aug13-11, 01:21 AM   #7
obviously it vl not show the output coz nobody written cout<<a;
line anywhere
i tried to write it at d end of all for loops bt it shows address of a integer
Aug13-11, 03:12 AM   #8
Recognitions:
Quote by akhil12123 View Post
cout<<a;
You'd need a loop and use cout<<a[i]; .
Aug13-11, 08:11 PM   #9
mdnazmulh, do not use the header iostream.h. It is deprecated, and not part of standard C++.
Please use the following instead.
Code:
#include <iostream>
And unless you want to prefix standard library names with "std::" use the following.
Code:
using namespace std;
Quote by jim mcnamara View Post
std::sort would work with arrays/pointers too.
Jun22-12, 11:26 PM   #10
Code:
#include <iostream.h>
void main()
const int max=50; //sets the maximum size of the array
int num[max]; //the array can be initialized from here num={2,3,6,4,3,7,8,,4.....n};
int holder;
//if array is initialized then no need for this for loop
  for(int m=0; m<max; m++)
  cout<<"Enter number "<<(m+1)<<" : ";
  cin>>num[m];
  for(int p=0; p<(max-1); p++)
	 for(int i=0; i<(max-1); i++)
		if(num[i]>num[i+1]) // comparison between two adjacent array elements
		 holder=num[i]; // holder holds the value temporarily
		 num[i]=num[i+1];
		 num[i+1]=holder;
  //now to print the sorted array
  for(int j=0; j<max; j++)
  cout<<" "<<num[j];        //This prints the array out in ascending order on the same line
                       //<<endl; could be placed at the end to print on different line
Jul17-12, 07:48 AM   #11
#include<conio.h>
void main ( )
int arr[100] , size , hold ;
START :
cout << "\n Enter the size of the array ( not more than 100 ) : " ;
cin >> size ;
if ( size > 100 )
cout << "\n Size is more than 100 ... Please re enter .. " ;
getch ( ) ;
clrscr ( ) ;
goto START ;
cout << "\n Enter " << size << "elements ... \n" ;
for ( int i = 0 ; i < size ; i ++ )
cin >> arr[i];
for ( i = 0 ; i < (size-1) ; i++ )
for ( int j = i+1 ; j < size ; j++ )
if ( arr[j] < arr[i] )
hold = arr[j] ;
arr[j] = arr[i] ;
arr[i] = hold;
cout << "\n The sorted array : \n ";
for ( i=0 ; i < size ; i++ )
cout << arr[size] << " ";
getch ( ) ;
New Reply
Thread Tools
Similar Threads for: numbers in Ascending Order in C++
Thread Forum Replies
Solving a PDE : 2 order in time, 4 order in space, mixed derivatives Differential Equations 20
under damp ing spring, eigen, 2-nd order eqn as 2 1-st order in matrix form. Calculus & Beyond Homework 1
Ascending to a higher state of being. General Discussion 1
