What Functions in Lp Spaces Satisfy the Transformative Integral Equation?
  • Context: Graduate
  • Thread starter Thread starter mmzaj
The discussion revolves around identifying a class of functions \(\phi(t)\) that satisfy a specific integral equation involving powers of \(t\) and their relationships in \(L^p\) spaces. Participants explore the implications of the equation, its reformulations, and potential solutions, while also considering the mathematical properties of the functions involved.
  • One participant seeks functions \(\phi(t)\) that satisfy the equation \(\int_T t^n \phi(t) \, dt = \left( \int_T t \phi(t) \, dx \right)^n\) for \(n=0,1,2,3...\), suggesting a connection to measure spaces.
  • Another participant argues that if such a function \(\phi\) exists, it may not have a simple structure, noting that scaling or summing functions that satisfy the equation does not yield new solutions.
  • A different viewpoint suggests that the problem can be reformulated to find \(\phi(t)\) in the equation \(\int e^t \phi(t) \, dt = \exp\int t \phi(t) \, dt\), indicating it is an analysis problem.
  • One participant claims that the only solution is the Dirac delta function, stating that \(\phi\) must be non-negative and integrate to 1, implying it describes a constant value.
  • Another participant provides a specific example of a solution using a normal density function, arguing that the two problems are not equivalent and can be solved in different ways.
  • There is a debate about the equivalence of the two integral equations, with some asserting that one can deduce the other but not vice versa, while others challenge this assertion with counterexamples.
  • Participants discuss the implications of equating power series and the conditions under which certain functions can be considered solutions, including the necessity for \(\phi(t)\) to be non-negative.
  • Concerns are raised about the assumptions made regarding the continuity and behavior of \(\phi(t)\) at infinity, as well as the implications of trivial solutions like \(\phi=0\).
Participants express differing views on the existence and nature of solutions to the integral equations. While some propose specific functions or conditions, others challenge the equivalence of the problems and the implications of the solutions, indicating that the discussion remains unresolved.
Participants note limitations regarding the assumptions about the continuity and behavior of \(\phi(t)\), as well as the implications of non-negativity and the existence of trivial solutions. These factors contribute to the complexity of the discussion without reaching a consensus.
mmzaj
Hi
i'm looking for some class of functions [tex]\phi(t)[/tex] that satisfy :
[tex]\int_T \ t^n \phi(t) \, dt = \left( \int_T \ t \phi(t) \, dx \right)^n ; n=0,1,2,3 ...[/tex]
from what i understand - if I'm not mistaken - the problem transforms to finding a set of measure spaces whose measure [tex]\ ds =\phi(t)dt[/tex] , and nth norm of [tex]t[/tex]
[tex]\left\|t\right\|_n = \left( \int \ t^n\ ds \right)^\frac{1}{n}[/tex]
satisfy :
1 - [tex]\int ds =1[/tex]
2 - [tex]\left\|t\right\|_n=\left\|t\right\|_1 ; n=2,3,4 ...[/tex]
obviously this problem is appropriately studied in [tex]L^p[/tex] spaces .
if I'm not mistaken , can you help me please , and if not , would you please advise .
Your two conditions seem to be mere reformulations of the original question.
If there exist such function phi then they do not have a nice structure, for example if phi satisfies your equation than 2 phi does not, similar for the sum of two such phi's.
Why would you think there exists a single such phi?
yes indeed , the two conditions are merely a reformulation , but a more formal one . i was hoping to transfer the problem to a field of math were it is more suitable to study . anyway , the problem is also equivalent to solving for [tex]\phi(t)[/tex] in :
[tex]\int \ e^t \phi(t) \, dt = \exp\int \ t \phi(t) \, dt[/tex]
this is an analysis problem , not else ! but it would be nice if you help .
I can't because I don't know the answer:smile:
My feeling is there should be at least one such a function phi ... but I don't know right now how to prove it or find that function.
Maybe you can introduce some artificial parameter, take some derivatives and transform the problem into a differential equation for phi ..a power series expansion for phi will not work because the integrals will not converge.
mmzaj said:
Hi
It's not possible, unless you allow the Dirac delta function [itex]\phi(t)=\delta(t-t_0)[/itex].
You can show that [itex]\phi[/itex] would have to be non-negative with integral 1, so it defines a probability distribution, and would have variance 0. So it would have to describe a constant value.
They're not the same - this problem can be solved in lots of ways.
For example, [itex]\phi(t)=\exp(-(t^2+1)/2)/\sqrt{2\pi}[/itex].
I got that example by letting [itex]\phi[/itex] be [itex]\lambda[/itex] times a standard normal density. So the left hand side is [itex]\lambda E(e^T)=\lambda e^{1/2}[/itex] and the rhs is 1, and [itex]\lambda=e^{-1/2}[/itex] gives the solution.
[tex]\int \ e^t \phi(t) \, dt =\int \sum^{\infty}_{n=0}\frac{t^n}{n!} \phi(t) \,dt[/tex] =[tex]=\sum^{\infty}_{n=0} \int \frac{t^n}{n!}\phi(t) \,dt =\sum^{\infty}_{n=0}\frac{1}{n!} \left( \int \ t \phi(t) \, dt \right)^n =\exp\int \ t \phi(t) \, dt[/tex]
so you see , they are the same !
I think the two problem are not equivalent. From your original equaiton you can deduce the the equation involving exponentials but not the other way round.
why !?? if you can go one way , certainly you can go all the way back !
Hm think about this example. You know x=2, y=3 from which you can conclude x+y=5, how ever the informstion x+y=5 is not enough to recover x=2,y=3, would you agree?:smile:
alright, I'll indulge you there ,
[tex]\int \ e^t \phi(t) \, dt=\exp\int \ t \phi(t) \, dt[/tex]
the LHS =
[tex]\sum^{\infty}_{n=0} \int \frac{t^n}{n!}\phi(t) \,dt[/tex]
the RHS =
[tex]\sum^{\infty}_{n=0}\frac{1}{n!} \left( \int \ t \phi(t) \, dt \right)^n[/tex]
now by equating both sides term by term we get :
[tex] \int \ t^n \phi(t) \, dt = \left( \int \ t \phi(t) \, dx \right)^n ; n=0,1,2,3 ...[/tex]
now i have to justify the last step :
consider this :
[tex] \sum^{\infty}_{n=0} \frac{a_n}{n!} = \sum^{\infty}_{n=0} \frac{b_n}{n!}[/tex]
implies :
[tex]a_n = b_n \ , n=0,1,2 ...[/tex]
QED
consider this :
implies :
QED
No, as I showed by my example above.
Another example:
Take
a_1 = 1, a_2 = 4, all other a_n =0
b_1 = 2, b_2 = 2, all other b_n =0
then both sums sum to 3 ...
ok , i'll have to admit it , you got me there ! but at least we can say :
if
[tex] <br /> \sum^{\infty}_{n=0} \frac{a_n}{n!} = \sum^{\infty}_{n=0} \frac{b_n}{n!}[/tex]
then :
[tex] a_n = b_n \ , n=0,1,2 ...[/tex]
is one solution . hence , if :
[tex] \int \ e^t \phi(t) \, dt=\exp\int \ t \phi(t) \, dt[/tex]
then :
[tex] <br /> \int \ t^n \phi(t) \, dt = \left( \int \ t \phi(t) \, dx \right)^n ; n=0,1,2,3 ...[/tex]
is one possible solution . as far as I'm concerned this is good enough .
if
then :
then :
Yes, it means exactly that you have the implication
[tex] \int \ t^n \phi(t) \, dt = \left( \int \ t \phi(t) \, dx \right)^n ; n=0,1,2,3 .. \Rightarrow \int \ e^t \phi(t) \, dt=\exp\int \ t \phi(t) \, dt[/tex]
The converse is not true, as gel immediately noticed.
This means if you find a solution for the left side of the impplication it will also be a soluton for the right hand side. It can however very well be that is no solution to the left hand side while the right hand side does allow a solution. So the two probleme are clearly not equivalent.
Which of the two do you actually want to solve? In either way, gel gave the answer together with nice explanations, thanks gel:smile:
nice ... [tex]\delta(t-t_0)[/tex] clearly satisfies the conditions... i understand the part where [tex]\int\phi(t)\ dt = 1[/tex] , but where did you get the condition where [tex]\phi(t) \geq 0[/tex] ? ... also i understand the part where [tex]\sigma^2 = 0[/tex] , but is this enough to conclude that [tex]\phi(t) = \delta(t)[/tex] exclusively ?? i mean 0 and [tex]\delta(t)[/tex] are rather trivial ! aren't they ??
If f(t)=tn, you have,
[tex] \int f(t) \phi(t)\,dt = f\left(\int t\phi(t),dt\right).[/tex]
By linearity, this applies to any polynomial. So, replacing f by f2,
[tex] \int f(t)^2 \phi(t)\,dt = f\left(\int t\phi(t),dt\right)^2\ge 0.[/tex]
Approximating any continuous function by polynomials, this extends to any continuous f (*). Assuming [itex]\phi[/itex] is continuous it follows that [itex]\phi\ge 0[/itex] (**)
There's a few issues here though
(*) I'm assuming [itex]\phi[/itex] goes to 0 fast enough at infinity, otherwise there could be problems taking this limit. Assuming exponential decay (or greater) as t->infinity is enough.
(**) if [itex]\phi[/itex] is only assumed to be measurable, and not cts, then it will be >= 0 'almost everywhere', meaning everywhere except on a set of length 0.
(***) the 'trivial' case [itex]\phi=0[/itex] doesn't make much sense because you get 00 on the rhs. If you adopt the convention 00=1, common when writing power series, polynomials etc, then [itex]\phi=0[/itex] is not a solution.
thanks a lot , i have to express my admiration in your approach . i'll get to you later with some questions , but for now
as for [tex]\phi(t) =0[/tex] , it's my bad , i didn't pay attention to the case where n=0 !
and of course thanks to you too pere .
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 36 ·
