Triple integration w/spherical coordinates
The problem involves finding the mass of a portion of a solid sphere defined by the inequality x² + y² + z² ≤ 25, specifically in the first octant where x, y, and z are all non-negative. The mass density function is given as f(x, y, z) = (x² + y² + z²)^(3/2). The original poster expresses confusion about the limits of integration and the transformation to spherical coordinates.
  • The original poster attempts to set up a triple integral but is uncertain about the limits for theta and phi in spherical coordinates. They seek clarification on the transformation of the mass density function and the volume differential in spherical coordinates.
Participants are exploring the setup of the problem, with some suggesting that the mass can be viewed as one-eighth of the total mass of the sphere. Guidance has been offered regarding the transformation of the mass density function and the interpretation of spherical coordinates, but specific limits for theta and phi remain unresolved.
The problem is constrained by the requirement to work within the first octant, which influences the limits for the angles in spherical coordinates. The original poster is also navigating the transition from Cartesian to spherical coordinates, which adds complexity to their understanding.
MAins
"Find the mass of part of the solid sphere x^2 + y^2 + z^ 2 ≤ 25 in the 1st octant x ≥ 0, y ≥ 0, z ≥ 0 where mass density is f (x, y, z ) = (x^2 + y^2 + z^2 )^3/2 ."
3.
These problems are really stumping me! I need somebody to work it out/explain it to me! What will the limits of integration be for the following question? What do i integrate? I know I need to transform it to spherical coordinates... but beyond that I'm lost.
I know it's a triple integral:
m = ∫∫∫(x^2 + y^2 + z^2)^3/2 dzdydx
transforming to spherical co-ordinates:
0 ≤ rho ≤ 5
0 ≤ theta ≤ ? (how do I figure this out?)
0 ≤ phi ≤ ? (ditto)
dzdydx = rho^2 sinphi drho dphi dtheta
What does f (x, y,z) transform to and how do I figure it out?
x^2+y^2+z^2=rho^2. What does that make f(x,y,z)? phi is the polar angle and theta is the equatorial angle. What range of these keeps you in the first octant? Refer to a picture of your preferred system of spherical coordinates.
… keep it simple …
Hi MAins! :smile:
You're making this too complicated:cry:
It's one-eight of the mass of the whole sphere.
Divide it into spherical shells, of radius r, from r = 0 to 5.
Then the mass of each shell is … ? :smile:
But just in case, you would like to learn how to do these problems!
Since [itex]\rho= \sqrt{x^2+ y^2+ z^2}[/itex], [itex](x^2+ y^2+ z^2)^{3/2}= \rho^3[/itex]. Thats the function you want to integrate.
Yes, you are correct that the differential of volume in spherical coordinates is [itex]\rho sin^2(\phi)d\rho d\theta d\phi[/itex]
Now, to determine what the limits of integration should be, think about what the variables in spherical coordinates mean. [itex]\rho[/itex] measures the distance from the origin, (0,0,0) to a point. Since your sphere is centered at (0,0,0) and has radius 5, [itex]\rho[/itex] must go from 0 to 5. [itex]\theta[/itex] measures the angle around the "equator" (think of it as "longitude"). For the full sphere, it goes from 0 to [itex]2\pi[/itex]. Here, you have just 1/4 of a full circle: so [itex]\theta[/itex] goes from 0 to ?? [itex]\phi[/itex] measures the angle down from the z-axis to the point (think of it as "co-latitude". For the full sphere, it goes from 0 to [itex]\pi[/itex]. You only want to go from the z-axis to the xy-plane, 1/2 way: so [itex]\phi[/itex] goes from 0 to ??
