Integral of Square of Reciprocal of √(a + cos t)
The discussion revolves around evaluating the integral of the square of the reciprocal of the square root of a function involving cosine, specifically \(\int_0^\pi \frac{dt}{(a + \cos t)^2}\), with the goal of demonstrating its equivalence to a given expression involving \(a\). The subject area includes calculus and complex analysis, particularly the application of the Residue Theorem.
  • The original poster attempts to use the Residue Theorem and makes substitutions to transform the integral. Some participants question the conditions on \(a\) and the correctness of the substitutions made, particularly regarding the limits and the nature of the poles in the complex plane.
Participants are actively engaging with the problem, offering suggestions for substitutions and clarifying conditions on \(a\). There is a recognition of potential issues with the original approach, and some guidance has been provided regarding the limits of integration and the nature of the integrand.
There are discussions about the constraints on \(a\), specifically that \(a > 1\) for the integral to be defined, and the implications of different values of \(a\) on the poles of the integrand. The original poster's approach may not align with the expected outcome under certain conditions.
e(ho0n3
[SOLVED] Integral of Square of Reciprocal of √(a + cos t)
Demonstrate that
[tex]\int_0^\pi \frac{dt}{(a + \cos t)^2} = \frac{a\pi}{(\sqrt{a^2 - 1})^3}[/tex]
where a > 0.
The attempt at a solution
I want to compute this using the Residue Theorem. The first thing I did was make the substitution [itex]\theta / 2 = t[/itex] so that
[tex]\int_0^\pi \frac{dt}{(a + \cos t)^2} = \int_0^{2\pi} \frac{d\theta}{2(a + \cos \theta/2)^2}[/tex]
I then made the substitution [itex]z = e^{i\theta/2}[/itex] so that
[tex]\int_0^{2\pi} \frac{d\theta}{2(a + \cos \theta/2)^2} = \int_{|z|=1} \frac{4z}{i(z^2 + 2az + 1)^2} \, dz = \int_{|z|=1} \frac{4z}{i(z - z_0)^2(z - z_1)^2} \, dz[/tex]
where
[tex]\begin{align*}z_0 &= \frac{-a + \sqrt{a^2 - 1}}{2}\\<br /> z_1 &= \frac{-a - \sqrt{a^2 - 1}}{2}\end{align*}[/tex]
Call the integrand of the last integral f(z). By the Residue Theorem
[tex]\int_{C} f(z) \, dz = 2\pi i \sum_{u \in D} \text{Res}(f; u)[/tex]
where u is a pole of f, C is the unit circle and D is its interior. The only possible poles are [itex]z_0, z_1[/itex]. I know [itex]z_0[/itex] is in D for all a > 0. However, [itex]z_1[/itex] is not in D if a > 5/4. What do I in this case? I would condition on the value of a but then my answer won't match up with that of the problem statement.
First off I think the condition that you want on a is a>1. The right hand side of what you want to prove is imaginary and the left side doesn't exist if 0<a<=1. Second, check the roots of your quadratic. You have an extra factor of 1/2 in there. I think you will find z0 is always in D and z1 never is.
Also z=exp(i*theta/2) for 0 to 2pi doesn't go all of the way around |z|=1. I think the substitution you want is just z=exp(i*theta). Start by just changing the limits on your original integral to 0 to 2pi. That will give you twice the answer you want, so you can just divide the result by 2. cos(theta) is symmetric around theta=pi.
I followed your suggestions and obtained the answer. Thanks a lot.
ahh this is a good problem
  • · Replies 19 ·
  • · Replies 20 ·
