Why Is There Lightning on Venus?
  • Context: Undergrad
  • Thread starter Thread starter pixel01
    Electrical storms
The discussion revolves around the phenomenon of lightning on Venus, comparing it to electrical storms on Earth and exploring the implications of Venus's atmospheric conditions on the occurrence of lightning. The scope includes theoretical considerations, conceptual clarifications, and speculative reasoning about the nature of storms on Venus.
  • Some participants note that the term "electrical storm" specifies the presence of lightning, contrasting it with storms that may not exhibit electrical activity, as seen on Jupiter.
  • One participant mentions that there is almost continual lightning on Venus, suggesting that if one were on the surface, they would observe frequent lightning and thunder, albeit with severe environmental hazards.
  • Another participant raises questions about the presence of lightning on Venus, pointing out that terrestrial smog clouds do not produce lightning and questioning why similar conditions on Venus would lead to lightning, particularly in relation to sulfuric acid clouds.
  • A participant speculates about the implications of sulfuric acid clouds causing rain on Venus, introducing the idea of "acid rain" as a potential outcome.
Participants express varying views on the nature of storms and lightning on Venus, with no consensus reached regarding the mechanisms that lead to lightning in its atmosphere or the comparison to Earth’s storms.
Limitations include assumptions about the similarities between Earth and Venus, the specific atmospheric conditions required for lightning, and the unresolved nature of how sulfuric acid clouds may influence electrical activity.
Astronomy news on Phys.org
That's just specifying that the storm has lightning. For example, there are often high winds on Jupiter, that are not accompanied by lighting. These would technically be "storms," but not electrical storms.
That is co-incidence!
I was just reading that there was lightning on Venus!
It was written that electrical activity in the Venusian atmosphere is providing new clues to understanding terrestrial lightning!
Yeah, from what I nuderstand, there's almost continual lightning on Venus. If you stood on the surface, anywhere on the surface, you would observe ligthing and thunder every few seconds, maybe every couple.
'Course, then you'd simultaneously crumple from the pressure, cook from the heat, and spit your lungs out in large chunks from the acid atmosphere.
-But the lighting would be kinda cool.
But there are funnier questions existing about this topic to make your mind think that why there should be any lightning on Venus?
Venus has terrestrial smog clouds which do not produce lightning and the every cloud causing lightning on Venus is associated with sulfuric acid! These make the topic really...well, I can't describe it! But you might say that, " But why shouldn't the terrestrial smog clouds not cause lightning on Venus just because they don't cause lightning on Earth?"
The answer is that, isn't Venus supposed to be Earth's Twin Planet and have similar mass, density and chemical composition? Well, that solves the smog cloud problem, but why the presence of Sulphuric Acid.
But something struck me.If the clouds which cause lighning, cause rain, ...raining sulphuric acid? Acid rain!
Well...?
9K
11K
