Register to reply
Curled up dimensions
by Bob3141592
Tags: curled, dimensions
Share this thread:
Bob3141592
#1
Apr30-08, 10:22 PM
P: 226
What do they mean by a dimension that's curled up? I'm having a hard time with this notion. What would such a dimension be like?
Phys.Org News Partner Physics news on Phys.org
Mapping the optimal route between two quantum states
Spin-based electronics: New material successfully tested
Verifying the future of quantum computing
Hurkyl
#2
Apr30-08, 10:29 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,092
Quote Quote by Bob3141592 View Post
Let's consider "curling up" one of our existing spatial dimensions. (just geometrically -- without worrying about how it might affect physics)
Do you recall old games like asteroids or pac-man where, if you go off of one edge of the screen, you reappear on the other side? Imagine that if you walked a mile East, you would up right back where you started. (Of course, this would mean the Earth is some weird sort of shape, but don't think about that)
Now, imagine how it would look if you only had to go a few hundred feet East before you wound up where you started. What about just 10 feet? 1 inch? 1 millimeter? 1 angstrom? With these small sizes, it would be more like you were a two-dimensional object than a three-dimensional one!
foolosophy
#3
May1-08, 12:03 AM
P: 35
String Theory is not scritctly a science yet - Its more of a mathematical philosophy that hasn't got any supporting evidence or observational data to conform any of the conclusions or predictions.
The mathematics in ST is logically consistent but that does not mean that it reflects reality in any way.
When String Theorists make statements such as "curled up dimensions" or even an infinite number of dimensions they need to support these theoretical constructs with reproducible evidence of some kind - and they cant - so far!
Bob3141592
#4
May1-08, 11:05 PM
P: 226
Quote Quote by Hurkyl View Post
Yes, I remember asteroids. Used to play it on the original bar tables. Used to stand in line to feed quarters into Pong. I told you I was almost old.
Tell me if I understand you right in these terms. I live inside this curled up dimension. Locally everything looks normal. I can survey a local map, and as I move around, overlapping at the edges of the pages I draw, I collect these maps into an atlas. After collecting, say nine maps, I notice the landmarks are familiar. I arbitrarily pick one map to be the center, and connect four maps, one to a side. That was pretty easy. It wasn't hard placing the last four corner sheets into a 3x3 grid either. As I'm making a list of distances to cities, I notice that cities on the opposite corners of this big map are actually close together. Everything on the extreme left is close to everything on the extreme right, but the top left is close to the top right, and bottom left is close to the bottom right. I devise a way to index to every point on the grid, and figure out a modulo function on the edges that let me calculate the distance between any two cities. I get up to write down this function and wonder what it means, when a breeze blows my maps apart. I reassemble them using a different map for the center, but now the mapping function I get is a little different for the corners. Any point on any sheet could be used as the origin, and I have a family of mapping functions at every point to every other point. the domain of the maps and the class of distance functions defines the topological space, right? I can generalize the family of functions into a single function in one added dimension, in the above case an oblate spheroid. It might have been a torus, but I suspect it'd take more than nine maps to figure that out. As long as that function is differentiable and conformal in my space, locally everything is guaranteed to seem normal to me. This also works even if my space is infinite, I just have to map it onto the extended Rieman sphere. Am I on track so far?
In the example you used, when you shrunk the curled up dimension from 100 feet to 10, that 10 feet was measured in your dimension. In mine, the maps I drew might be smaller, but on my maps the distance from Ank-Morpork to Quirm is still awfully far. I don't even think the feet that I use are the same kinds of feet as yours.
So you might see me as becoming more two dimensional as you curl me up, but I'd still feel three dee. The functions that define how things work in my space are still locally valid and presumably unchanged and possibly as I can measure it infinite.
It seems to me then that there isn't much difference between a dimension that's curled up and one that isn't. So unless I'm wrong in how I understood the above, I still don't understand what a curled up dimension means.
If we were living inside a curled up dimension, could we tell? How would we detect it? What properties of it could we measure?
LukeD
#5
May1-08, 11:44 PM
P: 355
First, it's obvious that a curled dimension is different from a non-curled one. For one, you can send a message in one direction and it could come back and hit you. Second, using just that method, you can show that it's possible to determine whether or not you are moving in a curled dimension (i.e., there is a difference between moving and not moving in a curled dimension) Consider a person sending 2 light beams in opposite directions and asking where they collide. A person standing still will give you one answer. However, if there were really no difference between standing still and moving, then a person who is moving would see them collide at a different point. However, this is a contradiction (since they could communicate to each other where they saw the light beams collide and they'd disagree. If you allowed this, there could be a lot of weird causality breaking things). This is of course assuming that the curled dimension is also flat, but I'm pretty sure similar things happen for non-flat curled dimensions.
Other odd things happen when you have multiple dimensions, some of which are curled and some of which are not curled, but I don't know any of the details.
foolosophy
#6
May2-08, 09:36 AM
P: 35
mathematical theories produce all sorts of weird and wonderful concepts - doesnt make them REAL though - even if they are logically consistent
What about a semi-curled dimension?
Or a dimension that does not interact with any other dimensions?
Or a oscillating or wave like dimension?
All mathematically consistent - BUT do they exist?
Bob3141592
#7
May3-08, 03:19 PM
P: 226
What's a semi-curled dimension? Would that be one where the maps on the sides overlap but the ones on top and bottom go off to infinity?
What's an oscillating or wave like dimension? I've never heard of that.
As for a dimension that doesn't interact with any other dimension, I guess that depends on what your definition of "is" is. If it doesn't interact with any other dimension, then I don't care if it exists or not. Makes no difference to me or to any theory.
Bob3141592
#8
May3-08, 03:49 PM
P: 226
Quote Quote by LukeD View Post
Sounds to me like you've described a relativistic space. In that case, why are there any big problems? Not long ago, wasn't it a question in cosmology whether our universe was open, closed, or flat? Locally it looks flat, but on larger scales all the evidence was for open, until they introduced dark matter. Then there was the supernova data and dark energy, and now the universe is way open and accelerating. All this always sounded speculative and I take it with a big grain of salt. But in any case, how would a curled up dimension be any different from such a closed universe, just on a seemingly larger scale?
You also said the curled dimension would have causality breaking if it was also flat. I don't know what that means. What is a flat curled dimension? What is a non-flat curled dimension?
BTW, I've always found the notion of looking at the back of my head rather disturbing. I avoid that unpleasantness by presuming the curvature of space is an irrational number. That way my line of sight will never return to it's starting point. I take comfort that I'm probably 100% right about that.
LukeD
#9
May3-08, 08:41 PM
P: 355
No, no, there's no causality breaking in assuming that the universe is flat and curled. There's causality breaking in assuming that there is no preferred reference frame (i.e., that you can't tell whether you or not you are moving). What I meant by flat was that this is a simple special relativity calculation (i.e., that that you are ignoring any of the effects of mass and energy on space-time and that the closedness of the dimension is just an intrinsic property of the dimension). If you have a flat, closed dimension, you can tell whether or not you are moving. I believe that something similar is true in general relativity as well unless certain constraints are put on the way dimensions curl and on the way they interact with mas, but I do not believe that this is done in string theory.
Hurkyl
#10
May3-08, 08:57 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,092
Don't you need some assumptions, like space being entirely homogenous in that direction, and in some sense static with respect to time?
Anyways, I'm of the (possibly wrong!) understanding that gauge theories can be thought of exactly as that -- e.g. you can attach a U(1) dimension to classical space-time, and electric charge manifests itself as something like velocity in that direction. (This is something I don't understand well)
Bob3141592
#11
May3-08, 09:49 PM
P: 226
I don't see how this follows. I thought it was correct to say that there is no preferred reference frame, at least in the dimensions I occupy (meaning, not in some higher dimension contained the curved one), and I didn't think the curvature of space qualified that statement.
Besides that, the argument about seeing the back of your head only applies with positive curvature and doesn't happen with negative curvature. I still don't understand why there should be causality problems in either case.
foolosophy
#12
May4-08, 12:22 AM
P: 35
Well I just made them up to make a point.
Not sure if they exist in mathematical theory either
I wouldnt pay much attention to me when I am making stuff up OFF the top of my head
(altough thinking about it now, I dont see why an OSCIALLTING dimension could not be a feasible mathematical construct. I would imagine it would be a dimesion that begns to curl one way and then curl the other way producing a wave like pattern - non-linear but period if you like???)
arivero
#13
May4-08, 10:40 AM
PF Gold
arivero's Avatar
P: 2,893
Not sure if we should clarify the use of the word "flat" in this thread. It is usually interperted as zero "gaussian curvature", a property which is told of pairs of directions, but not of a single direction. Think about the plane, the cone, the cylinder, the torus and the sphere.
also, check http://mathworld.wolfram.com/FlatManifold.html and http://en.wikipedia.org/wiki/Curvature
Bob3141592
#14
May4-08, 10:43 AM
P: 226
Quote Quote by foolosophy View Post
My problem is that I don't know enough to be sure when you're making stuff up and when you aren't. Without such an indication, I'd have no choice but to simply not pay attention to you at all, since I'm really trying to learn something here.
oldman
#15
May5-08, 04:38 AM
P: 622
I wish I could help you here, but I haven't even found a satisfactory description of what a dimension is, or is like, yet. This might develop into an interesting thread if you could start at the beginning and describe an ordinary dimension, say one of the ones we call "space dimensions" (the time one is too difficult). Then one might be able to get a handle on how to describe a curled-up dimension.
Come to think of it, I don't even know what "space" is.
I'm almost too old, it seems.
foolosophy
#16
May5-08, 08:59 AM
P: 35
You learn BEST by making stuff up off the top of your head.
If you wish to regurgitate accepted standard models of nature then just read dozens of text books - that a different sort of learning - although its important, its not critical to me.
Free thinking is far more challenging than PLAIN LEARNING and it opens up many horizons and to enter this realm ONE must ponder the wrong or neglected questions
Are you afraid to improvise in science? thats what science is supposed to be for it to progress.
paw
#17
May5-08, 01:27 PM
P: 168
You learn BEST by making stuff up off the top of your head... ...Are you afraid to improvise in science? thats what science is supposed to be for it to progress.
Not at all! But you clearly don't understand science at all. Science requires that you provide experimental evidence for your theories. Or at the very least you must show that experimental evidence could be provided, in priciple, given an appropriate state of the art.
Making things up off the top of your head is, at best, philosophy and, more likely, nothing more than nonsense.
Bob3141592
#18
May5-08, 10:10 PM
P: 226
Quote Quote by oldman View Post
What is a dimension? The flippant answer is "anything you want it to be." It's almost a religious question to some. Poetically it's a measure of a fundamental reality about the universe. In other words, it's one necessary measure of an observable. Mathematically (I think, help me out here) it is an orthogonal parameter in a mapping from the universal set onto the universal set. You just have to define your universal set.
The trick is in knowing everything about your universal set. If you know everything, you can map one point in reality (an element of the universal set, call it e) to any other point of reality within a neighborhood of x. If you know everything, the radius of that neighborhood might be unbounded. Does that seem right?
Anyway, if you don't know everything and don't have enough parameters, you can only map to subspaces of the universal set, and it won't be sensibly ordered, at least in some ways (in exactly the number of dimensions you're short ways. I think). If you have too many dimensions, then n of them measure some combination of other dimensions, and not what you think it does. In this case some combinations of parameters will be able to predict some things but won't apply to others. This makes it very hard to decide which parameters to get rid of.
You don't even have to pick just the exact right dimensions, either. As long as the n dimensions you pick contain all of the n independent orthogonal vectors, then everything will work out the same. I doubt the equations which defined the mappings would even be more cumbersome.
So while it's not exactly "anything you want it to be" it's still sort of close to that.
Register to reply
Related Discussions
Extra dimensional equation for energy. Curled dimensions, scales, QM Quantum Physics 0
The Cause Of Dimensions Being Curled Up And Its Universality Beyond the Standard Model 0
Curled Up / Small Dimensions In String Theory Beyond the Standard Model 11
Why do extra dimensions have to be curled up ? General Physics 27
