What is the maximum height reached by the arrow?
The discussion revolves around calculating the maximum height reached by an arrow shot from a height of 5 ft at an angle of 30 degrees with an initial velocity of 300 ft/sec. Participants explore the parametric equations governing the projectile's motion, the time of flight, and the distance to a target at the same height as the launch point. The scope includes mathematical reasoning and technical explanations related to projectile motion.
  • Homework-related
  • One participant requests the parametric equations for the projectile's path and seeks to determine the distance to the target and the maximum height.
  • Another participant suggests that solving differential equations may not be necessary and expresses uncertainty about the appropriate method due to the lack of context from the original poster.
  • A third participant provides the equations of ballistic motion without air resistance and derives the parametric equations, indicating the initial vertical velocity and calculating the total flight time as approximately 9.38 seconds.
  • This participant also mentions the calculation for the range of the arrow based on the flight time.
  • A later reply addresses the maximum height by referencing the vertex formula for a parabola and suggests calculating the time at which the maximum height occurs.
Participants express differing views on the methods to solve the problem, with some advocating for simpler approaches while others suggest more complex methods like differential equations. The discussion does not reach a consensus on the best approach or the final answers to the questions posed.
There are limitations regarding the assumptions made about air resistance and the specific definitions of variables in the equations presented. The calculations depend on the accuracy of the parameters used, and the discussion does not resolve these aspects.
jen043081
An archer shoots an arrow from a height of 5 ft. at an angle of inclination of 30 degrees with a velocity of 300 ft/sec. Write the parametric equations for the path of the projectile and sketch the graph of the parametric equations. If the arrow strikes a target at a height of 5 ft then how far is the target from the archer? For how many seconds is the arrows in flights. What is the maximum height reached by the arrow?
I can think of a number of ways to do this, some involving solving differential equations. Since you have not shown any work of your own on this problem or even what you feel you DO understand about it, I have no idea which method would be appropriate for your level and cannot answer.
You don't need differential equations to solve this.
Look, the equations of ballistic motion without air resistance are:
x[t]=x0+v0*t*cos y[t]=y0+v0*t*sin+a*(t^2)
where (x0,y0) is initial point, v=initial velocity, b=angle with x-axis, g=acceleration due to gravity, and t=time since launch. Therefore, the parametric equations are
x[t]=300*cos[30]*t y[t]=5+150*t+(-32)*(t^2)
It starts with intial vertical velocity v0=150 and hits the target with vertical velocity -150. Since v=v0+a*t, we have -150=150-32*t, giving a total flight time of t1=9.38 seconds.
The range is given by plugging t1 into the formula x=x0+v0'*t+a'*(t^2)/2 along with x0=0, v0'=v0*cos=300*cos[30], a'=horizontal acceleration=0.
x1=300*cos[30]*9.38
Which should give you the right answer when put into a calculator.
Forgot height. Sorry! The maximum or minimum of a parabola y=ax^2+bx+c occurs at x=-b/(2a), so the max height occurs at t=150/64. Plug that into y[t] to get max height.
10K
  • · Replies 16 ·
