Help with slowing down this simple motor
  • Thread starter Thread starter heathphysics
    Motor
The discussion centers on methods to slow down a motor for specific applications. Participants recommend reducing voltage as the most straightforward approach, with a particular emphasis on using a rheostat for adjustable speed control. The use of a rheostat allows for real-time tuning, making it a preferred solution over fixed resistors. Other suggestions, such as using less wire, were deemed ineffective.
  • Basic understanding of electric motors and their operation
  • Familiarity with voltage and resistance concepts
  • Knowledge of rheostats and their applications in circuit design
  • Experience with wiring and electrical components
  • Research how to implement a rheostat in motor control circuits
  • Learn about voltage regulation techniques for electric motors
  • Explore alternative methods for controlling motor speed, such as PWM (Pulse Width Modulation)
  • Investigate the impact of wire gauge on motor performance and speed
Electronics hobbyists, engineers working on motor control projects, and anyone interested in optimizing motor speed for specific applications.
heathphysics
The motor that I've built is the one below its a working motor and spins fast, but I have to slow it down to as much as I can for its intended purpose. Does anyone have any ideas as to how I can make this motor spin slowly. I've tried using less wire but it doesn't work. Note: for the piece of cork, I've used wiring tape instead. Help!
Tried lowering the voltage? or putting in a resistor?
That's a very nice illustration, Healthphysics.
I agree with Deakie that dropping the voltage is probably the easiest way. I'd modify his resistor suggestion by using a rheostat. That will allow you to tune it on the fly rather than having to swap out hard-wired parts until you get the speed that you want.
