Interaction of a Current Loop with a Magnetic Field
The discussion centers on calculating the torque exerted on a current loop due to its interaction with a magnetic field. Given a current of 0.500 A and a magnetic field strength of 0.300 T, the torque about the vertical axis is derived using the equation for torque in a magnetic field. The initial position of the loop is at an angle of 30 degrees, leading to a calculated torque of 1.03 x 10^-8 N*m. The correct application of trigonometric functions is crucial for accurate results.
  • Understanding of torque in magnetic fields
  • Familiarity with the formula for torque (τ = I * B * A * sin(θ))
  • Basic knowledge of current loops and magnetic fields
  • Ability to perform trigonometric calculations
  • Study the derivation of the torque formula for current loops in magnetic fields
  • Learn about the effects of varying angles on torque calculations
  • Explore the applications of torque in electromagnetic devices
  • Investigate the relationship between current, magnetic field strength, and torque
Students and educators in physics, electrical engineers, and anyone involved in the study of electromagnetism and torque in current-carrying loops.
HELLO11
Assume that the current flowing into the loop is 0.500A . If the magnitude of the magnetic field is 0.300 T, what is torque , the net torque about the vertical axis of the current loop due to the interaction of the current with the magnetic field?
the loop is initially positioned at (theta)=30 degrees
http://i283.photobucket.com/albums/kk319/bigcurly_09/render4.gif
i know with the sin i have to subtract 90- theta
When i plug in all the numbers correctly i get 1.03*10^-8
Can anyone help me i am on my last try. The answer must be in N*m
Can anyone help me?
Please provide the complete statement of the problem exactly as it was given. (A diagram would be helpful; lacking that, describe the direction of magnetic field compared to the orientation of the current loop.)
  • · Replies 37 ·
