Why Can't Photons Have Rest Mass?
The discussion centers around the question of why photons cannot have rest mass, exploring concepts related to momentum, energy, and the definitions of mass in the context of special relativity. Participants examine the implications of these concepts both theoretically and mathematically.
  • Some participants note that while photons have no rest mass, they possess momentum, which can be demonstrated experimentally, such as in Compton scattering.
  • It is mentioned that special relativity asserts no mass can be accelerated to exceed the speed of light, leading to the conclusion that photons must have zero rest mass.
  • A mathematical relationship is presented: E^2 = (pc)^2 + (m_0 c)^2, indicating that if the rest mass (m_0) is zero, then energy (E) equals momentum (p) times the speed of light (c).
  • Participants discuss the distinction between rest mass and relativistic mass, with some stating that rest mass is zero and thus does not relate meaningfully to momentum.
  • One participant explains that relativistic mass is defined differently and can be related to momentum through the equations E = mc^2 and E = pc.
  • Another participant argues that if something moves at the speed of light, its relativistic mass would approach infinity, leading to the conclusion that its rest mass must be zero.
Participants generally agree that photons have zero rest mass, but there are differing views on the implications of this regarding momentum and the definitions of mass. The discussion remains unresolved on certain aspects of how to relate momentum to mass.
There are limitations in the discussion regarding the definitions of mass, the implications of relativistic versus rest mass, and the mathematical relationships that are not fully resolved. Some assumptions about the nature of mass and momentum are also left unexamined.
This discussion may be useful for students and enthusiasts of physics, particularly those interested in the principles of special relativity, the nature of light, and the definitions of mass in different contexts.
fireball3004
I understand photons have no rest mass, but I also learned in my physics class p=h/(lambda), and that mass depends on the frequency, my question is why can't something moving at c have rest mass if it can have... momentum I suppose is the term...
If you define momentum as the ability to deliver an impulse, then light has it. This is experimentally demonstrable. See Compton scattering.
It is a tenet of special relativity that no mass can be accelerated so as to break the light barrier in any frame of reference, therefore the photon is assigned zero rest mass on principle. Experiments to test this set a very low possible mass for the photon.
See the FAQ on the Experimental Basis of Special Relativity.
It may sound contradictory to some, but that's the way it seems to be.
The general relationship between rest mass (a.k.a. invariant mass), momentum and energy is
[tex]E^2 = (pc)^2 + (m_0 c)^2[/tex]
If [itex]m_0 = 0[/itex], then E = pc.
It's possible to show that
[tex]\frac{v}{c} = \frac{pc}{E}[/tex]
so if E = pc, then v = c.
Reversing this logic, we can see that if v = c, then [itex]m_0 = 0[/itex].
thanks you guys, that helps a lot, but then what is the relationship of the momentum of light to mass of light? because I know classically p=MV
That depends on which kind of mass you're talking about. If you're talking about "rest mass" a.k.a. "invariant mass", it's zero, so there's no meaningful relationship between it and the momentum. To get the momentum you use [itex]E = pc[/itex].
If you're talking about "relativistic mass" then you can combine [itex]E = mc^2[/itex] and [itex]E = pc[/itex] to get [itex]p = mc[/itex].
You have to distinguish between rest mass and relativistic mass before solving your problem. Rest mass is the measure of inertia of a body with very low velocity ( in fact, at rest ) while relativistic mass is the measure of inertia at certain velocity v. The relationship between these two is relativistic mass=rest mass /(sqaure root of (1-v^2/c^2)). If we put rest mass=a, while a not equal to 0, and v=c(the velocity of light) in the equation, the relativistic mass will equal infinity, which is impoosible. By the method of contradiction, therefore we know that something moves at velocity c must have rest mass a equals to 0. You may also look the question in this way. Someone try to measure rest mass of a photon and therefore try to make that photon at rest. However we know that the photon will be annihilated if we stop it. Therefore photon has no rest mass.
As the momentum is defined as the velocity times relativistic mass ( not rest mass ) in special relativity, p=mc in case of photon ( a quantum particle of light ) where m is the relatvistic mass and c the speed of light.
Its more simple than that since relativist mass, m, is defined as the ratio of the magnitude of momentum to speed and therefore p = mv by definition. Since v = c then p = mv for a photon.
Pete
...I think I've got the gist of it now, thanks guys
  • · Replies 19 ·
  • · Replies 102 ·
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 55 ·
