Help with Gravitation questions
  • Thread starter Thread starter wikidrox
    Gravitation
The discussion focuses on solving gravitational force problems using established physics formulas. For the first question, the gravitational force between a 70 kg boy and a 60 kg girl is calculated using the formula F=Gm1m2/r^2, where G is the gravitational constant. The second question involves determining the required rotational speed of the Earth for a 100 kg person to experience no force on a scale at the equator, which is solved using centripetal force equations, yielding a speed of 7900 m/s and a rotation period of approximately 84 minutes.
  • Understanding of Newton's Law of Universal Gravitation
  • Familiarity with centripetal force concepts
  • Knowledge of the gravitational constant (G)
  • Basic algebra for solving equations
  • Study the derivation and applications of Newton's Law of Universal Gravitation
  • Learn about centripetal acceleration and its relation to circular motion
  • Explore the implications of gravitational force in real-world scenarios
  • Investigate the effects of varying mass and distance on gravitational attraction
Students studying physics, educators teaching gravitational concepts, and anyone interested in understanding the principles of gravitational attraction and centripetal force.
wikidrox
The first one just confuses me because of the word in the brackets.
1. A 70kg boy stands 1.0 m away from a 60 kg girl. Find the force of attraction (gravitational) between them.
For this would I just sub the values into F=Gm1m2/r^2?
The second question is giving me a lot of problems.
2. How fast would the Earth (r=6400km) have to be spinning befor a 100kg person would exert no force on a scale at the equator? Assume the Earth is a perfect sphere and it's mass is 6.0 * 10^24 kg.
For this I took F=ma and subbed in a=4 (pi)^2 r / T^2. Then I made F=0 and solved for T, but my answer gave me a period of 44 hours. This can't be write since it would have to be spinning faster than 24 hours. Please help.
It's just a joke--gravitational attraction versus the non-physics kind. :wink:
...For this would I just sub the values into F=Gm1m2/r^2?
Right.
Check out this thread:
https://www.physicsforums.com/showthread.php?t=17606
For the first question, you are correct. You can use the formula F=Gm1m2/r^2 to calculate the force of attraction between the two individuals. Just remember to use the correct units for mass (kg) and distance (m).
For the second question, you are on the right track. However, you need to use the formula for centripetal force, which is F=mv^2/r. This is because the person on the equator is moving in a circular motion due to the Earth's rotation. So, the force exerted by the Earth's gravity (F) must be equal to the centripetal force (mv^2/r) in order for there to be no net force on the person.
Substituting the values given, we get:
F=mv^2/r
6.67*10^-11 * 6.0*10^24 * 100 / (6400*1000)^2 = 100*v^2 / 6400*1000
v^2 = 9.8*6400*1000
v = 7900 m/s
This means that the Earth would have to be rotating at a speed of 7900 m/s at the equator for a 100 kg person to not exert any force on a scale. This is equivalent to a rotation period of about 84 minutes, which is much faster than the Earth's actual rotation period of 24 hours. So, your answer of 44 hours is not correct.
I hope this helps! Let me know if you have any other questions.
  • · Replies 23 ·
  • · Replies 18 ·
