sen_almighty
Can someoe explain what 32bit and 64bit mean when you're talkin bout comp applications or processers or what not.
The discussion revolves around the concepts of 32-bit and 64-bit architectures in computer applications and processors. Participants explore the implications of these terms in relation to processing capabilities, software compatibility, and data transmission.
Participants generally agree on the definitions of bits and bytes, but there is disagreement regarding the implications of 32-bit vs 64-bit architectures, particularly concerning software compatibility and performance. The discussion remains unresolved on several technical points.
There are limitations in the discussion regarding the definitions of bytes and bits, as well as the nuances of data processing speeds and software requirements. Some assumptions about the instantaneous nature of data transfer are also challenged.
This discussion may be useful for individuals interested in computer architecture, software development, and the technical specifications of processors and operating systems.
Originally posted by sen_almighty
yes, i know that, but 32bit OS's and software, and 64bit, like the Operton is 64bit and the P4 is 32bit and stuff, wat does that mean?
Originally posted by BoulderHead
Hello sen_almighty,
Generally these terms are applied to the processors, and they are speaking of how many individual bits the CPU can perform functions on in one clock cycle. The 64-bit processor can operate on twice as many bits as its 32-bit little brother. There are other considerations such as software having been written to transfer a certain number of bits each clock cycle, and this means the jump to 64-bits will necessitate some software revision.
Originally posted by russ_watters
Some clarifications:
A byte is 8 bits. Sometimes a 9th bit is added for error correction (a checksum) but it isn't part of the byte.
The Opteron is AMD's 64 bit processor (the Itanium is Intel's 64 bit processor).
Nothing in a computer is instantaneous. If a data path is 64 bits, all 64 bits get to their destination at the same time, but it still takes time for them to get there.
In order to use a 64 bit processor, you need a 64 bit operating system (the Opteron actually does BOTH 32 bit and 64 bit). Microsoft is currently working on several flavors of 64 bit OSs.
The benefit of 64 bit is basically just allowing you to use larger numbers. Sometimes it makes applications faster, sometimes it doesn't.
For video cards, 64 bit vs 32 bit is talking about memory bandwidth. Its the same basic idea - information is transferred in groups of 32 or 64 (or 16 or 128) bits but the graphics processors are all still 32 bits. Memory bandwidth is EXTREMELY important for 3d rendering which is why you hear it advertised.
Tey here;Originally posted by LogicalAtheist
I want to know more about these 64 bit OS's
Anyone got some links? with pics? thanks!
Originally posted by damgo
Yes, it's the size of the data path -- mainly this is important for memory addressing, but arithmetic too. A 32-bit processor/program can only easily access 4 gigabytes of memory, and a 16-bit one only 64 megabytes; anything more and it slows way down. A 64-bit one can access ~16,000,000,000 gigabytes. These also give the largest numbers the program/processor can operate on at once.
Originally posted by Artman
The CPU can handle longer files names, as in the change from Win 3.1 to Win95 allowed longer file names.
