What Is the Mathematical Derivation of Brewster's Angle?
The discussion revolves around deriving Brewster's angle in the context of optics, specifically focusing on the conditions for zero reflectance when light is incident on a transparent material. The problem involves manipulating equations related to the electric vectors of incident and reflected beams.
  • The original poster attempts to manipulate a given formula to derive Brewster's angle, expressing uncertainty about the trigonometric aspects involved. They question whether their approach to solving for the refractive index, n, as a quadratic is correct.
  • Some participants suggest looking into trigonometric identities, particularly double-angle formulas, to simplify the expressions encountered.
  • Another participant questions the origin of the equations used for the electric vectors, leading to a clarification about their relation to Fresnel equations.
Participants are actively engaging with the problem, exploring different mathematical manipulations and clarifying concepts. There is a recognition of the need for further exploration of trigonometric identities to aid in the derivation process. While some progress has been made, there is no explicit consensus on the final approach or solution yet.
The discussion highlights the complexity of the trigonometric relationships involved and the potential for misunderstanding in the derivation process. Participants are navigating through the constraints of the problem and the mathematical requirements without reaching a definitive conclusion.
duo
A beam of radiation, whose electric vector is in the plane of incidence, is incident at an angle [tex]\theta[/tex] from air onto a transparent material of refractive index, n. Given the relationship between the electric vectors of the reflected (E'') and incident (E) beams derive the condition for zero reflectance for this polarization (the Brewster angle)
[tex]\frac{E''}{E}[/tex] = [tex]\frac{n^2cos(\theta)-\sqrt{n^2-sin^2({\theta})}}{n^2cos(\theta)+\sqrt{n^2-sin^2({\theta})}}[/tex]
[tex]tan(\theta)=n[/tex] (condition for zero reflectance)
So, basically, I think I just need to manipulate the first formula until I arrive at the expression for Brewster's angle. Since E'' is the reflect beam, it must equal 0. So I can set [tex]n^2cos(\theta)[/tex] equal to [tex]\sqrt{n^2-sin^2({\theta})}[/tex]. When I try to solve from there I run into problems. If I square the entire expression then I have a quadratic which I can solve for [tex]n^2[/tex].
[tex]n^4cos^2(\theta) - n^2 + sin^2(\theta) = 0[/tex]
solve using quadratic formula with [tex]a = cos^2(\theta), b=-1, c=sin^2(\theta)[/tex]
This seems like it would be along the right lines since I would ideally end up with [tex]sin^2(\theta)[/tex] divided by [tex]cos^2(\theta)[/tex], which I would take the square root of to find n. The problem there is that it I end up with an expression:
[tex]n^2 = \frac{1 +/- \sqrt{1-4cos^2(\theta)sin^2(\theta)}}{2cos^2(\theta)}[/tex]
But I have no idea what to replace [tex]4cos^2(\theta)sin^2(\theta)[/tex] for... I assume it is some sort of trigonometric expression? But I have no idea where to start. I think that in general it's pretty obvious that E'' must equal zero, since that's more or less stated as part of the problem, my weakness is the trig required to do this. Am I along the right path when I try to solve for n as a quadratic? Any hints on how I should approach the expression if I am? Or am I doing this the completely wrong way? I thought I could maybe multiply the top and bottom of the expression by say [tex]n^2cos(\theta)+\sqrt{n^2-sin^2({\theta})}[/tex], just because that looks sort of like something might cancel out conveniently... but it doesn't seem to simplify things at all. Anyways, any help would be greatly appreciated!
Things seem to be on the right track.
It will help you to look up the trig double-angle formulas for [tex]\sin(2\theta)[/tex] and [tex]\cos(2\theta)[/tex], and see if one or both of them can be used in your last expression.
The solution
This equation could be solved by replacing [tex]2cos^2(\theta)\sin^2(\theta)[/tex] with [tex]sin2(\theta)[/tex].
You will get an equation which is
[tex]n^2 = \frac{1 \pm \sqrt{1-sin^2{2(\theta)}}}{2cos^2(\theta)}[/tex]
substitute [tex]1 - sin^2{2(\theta)}[/tex] with [tex]cos^2{2(\theta)}[/tex]
and manipulate the formula until you get [tex]\frac{1 \pm ({2cos^2\theta-1})}{2cos^2\theta}[/tex]
continue your work and you will solve the question with [tex]n^2=1[/tex] , [tex]n=\pm 1[/tex] or [tex]n^2=tan^2\theta[/tex] , [tex]n = \pm tan\theta[/tex]
Where did the equations for the amplitude of the electric vectors come from? (the numerator and denominator of first post)?
Figured it out they, come from the fresnel equations.
Cipher made an error it should be 2cos(theta)sin(theta) = sin(2theta)
  • · Replies 20 ·
