Harry Wertmuller's Doubt on Windmill Energy Proportionality
  • Context: High School
  • Thread starter Thread starter HarryWertM
    Energy Windmill
The discussion centers around the relationship between energy and wind speed in the context of windmill energy generation. Participants explore whether energy is proportional to the cube or square of the velocity, examining theoretical and practical implications in renewable energy applications.
  • Harry Wertmuller expresses confusion over the claim that energy is proportional to the cube of the velocity, suggesting it should be proportional to the square of the velocity.
  • Some participants propose that the relationship is indeed cubic due to factors such as pressure increase with velocity and the laws governing fan performance.
  • One participant mentions that in their Alternative Energy class, they learned that as wind input increases, output increases cubically, while resistance also increases, affecting the operation of windmills.
  • A participant explains that aerodynamic drag and lift forces vary with the square of speed, leading to power varying with the cube of speed, based on the relationship between force and speed.
  • Another participant elaborates on the calculation of kinetic energy, indicating that the energy per unit time in the air passing through the windmill is proportional to the cube of the air velocity.
  • Bob S. introduces the concept of the Betz limit, noting that it is not possible to extract all energy from wind and discusses the average performance of windmills in relation to their maximum design power.
Participants express differing views on whether energy is proportional to the cube or square of the velocity, with no consensus reached. Some support the cubic relationship, while others question or challenge this assertion.
Participants reference various principles and laws related to wind energy, but there are unresolved assumptions regarding the definitions and conditions under which these relationships hold true. The discussion also touches on practical implications of these theoretical claims.
HarryWertM
Reading about renewable energy on the Internet a short time ago, I came across the statement that "energy is proportional to the cube of the velocity".
Huh? I thought energy was proportional to the _square_ of the velocity. After all, we're not talking relativity here.
-Harry Wertmuller
HarryWertM said:
Reading about renewable energy on the Internet …
Hi Harry! :smile:
Where on the internet?
I googled "energy is proportional to the cube of the velocity", but only got two hits, neither of them relevant. :confused:
Maybe it's just an error ! :)
It's true. The reason is that an increase in velocity also involves and increase in pressure. Here are the fan laws: http://www.delhi-industries.com/Engineering/Tips/FanLaws.asp
1 CFM varies Directly with RPM (CFM 1 / CFM 2 = RPM 1 / RPM 2)
2 SP varies with the SQUARE of the RPM (SP 1 / SP 2) = (RPM 1 / RPM 2)2
3 HP varies with the CUBE of the RPM (HP 1 / HP 2 = (RPM 1 / RPM 2)3
You need to substitute the first equation into the third...
Learned the same law in my Alternative Energy class at community college. It's true alright, and it's one of the factors that made our instalation of the school's windmill a lot easier. You see, as input (wind) increases by x, otuput increases by x3, and resistance (load) increases proportionally with output. So, as windspeed goes up, the blades' resistance to acceleration goes up exponentially, which keeps the blades from spinning too fast and ripping themselves apart.
Aerodynamic drag and lift forces vary with the square of the speed (assuming sub mach air speeds here). Since power = force x speed, then power varies with the cube of the speed (speed^2 for force component x speed).
-Harry Wertmuller
Here is how I think of this surprising, but true, fact:
1. The energy per molecule (or mole, or gram, or whatever) of air is proportional to the square of the air velocity.
2. The number of air molecules per unit time, that pass through the windmill blades, is proportional to the air velocity.
Multiply the quantities in these two statements and we find:
The power (i.e. energy per unit time) in the air passing through the windmill is proportional to the cube of the air velocity.
-Harry Wertmuller
the column of air in 1 second= v
the volume of air= va (a= cross area)
the mass of air=vad (d=density)
the kinetic energy= 1/2 m v v
=1/2 vad v v(vad=m)
= 1/2 ad (v v v)
hope you got the answer
It is not theoretically possible to remove all the energy from wind, because the air has to go someplace after passing through the windmill. This limit is called the Betz limit, ~59%. Actual windmills achieve ~40 to 45% maximum. Furthermore, because the wind velocity distribution is approximated by the Rayleigh distribution
http://en.wikipedia.org/wiki/Rayleigh_distribution
windmills on average operate at only ~35% of their maximum design power. So a 1.5 MW windmill on average produces only about 500 kW.
Bob S.
  • · Replies 32 ·
  • · Replies 60 ·
  • · Replies 35 ·
11K
  • · Replies 17 ·
