Projection Problem Homework: Describe Vector V in Terms of a and b
  • Thread starter Thread starter himynameismar
    Projection
The discussion revolves around solving the projection problem of vector V onto the vectors (a,b) and (-b,a). The user attempts to express V in terms of a and b using projection equations and arrives at the equations ax + by = -bx + ay. The solution involves manipulating these equations to express y in terms of x and ultimately leads to the conclusion that both projection equations must equal 1. A key insight is that the vectors (a,b) and (-b,a) are orthogonal, simplifying the problem-solving process.
  • Understanding of vector projection concepts
  • Familiarity with linear algebra and solving linear equations
  • Knowledge of orthogonal vectors and their properties
  • Ability to manipulate algebraic expressions
  • Study vector projection formulas in detail
  • Learn about orthogonal vectors and their implications in linear algebra
  • Explore methods for solving systems of linear equations
  • Investigate applications of vector projections in physics and engineering
Students studying linear algebra, mathematics enthusiasts, and anyone tackling vector projection problems in physics or engineering contexts.
himynameismar
The projection of the vector V onto (a,b) = (a,b)
The projection of the vector V onto (-b,a) = (-b,a)
Describe V in terms of a and b
I let V=(x,y) then place that into the projection equation for each to get:
[(x,y)(a,b)/(a,b)(a,b)](a,b) = [ax+by/a^2+b^2](a,b)=(a,b)
[(x,y)(-b,a)/(-b,a)(-b,a)](-b,a) = [-bx+ay/b^2+a^2](-b,a)=(-b,a)
After seeing this I realized that:
k(V)=V so k has to equal 1
so both [ax+by/a^2+b^2] and [-bx+ay/b^2+a^2] should eqaul 1
Then I let:
[ax+by/a^2+b^2]=[-bx+ay/b^2+a^2]
the denominators cancel each other out and I'm left with
ax+by=-bx+ayAfter that I solved for y to get y=(a^2+b^2-ax)/b
Subsituting that in I get:
[-bx+a[(a^2+b^2-ax)/b]/b^2+a^2]
Reducing and all that other good stuff I finally get x=[a^2+b^2-(a^3/b)+[(ab^2)/2]]/[(a^2)/b]-b]
I am unaware if I am doing this correctly, maybe it's just how it looks that is throwing me off. Any advice or help would be greatly apperciated. THanks
You had two equations and two unknowns.
This = 1 and That = 1.
You only used one equation
This = That.
Now use either of the original... they're linear so you could solve them via linear methods but its just as easy in this case to solve one eqn for y in terms of x and substitute it into the other. When you're done verify that both original equations are true.
There is however a quicker way to do this problem... by noting that the two given vectors are orthogonal to each other!
