Thread Closed
About the dimensions of the universe
Share Thread Thread Tools
May6-08, 09:24 AM   #1
I have been reading about dimensions, and I understand that:
A dot has no dimensions
A line has 1 dimension
A square has 2 dimensions
A cube has 3 dimensions
A tesseract has 4 dimensions
And time is another dimension just like those
In theory we can think of lines and squares, but we can't build them in the real world. If any of all the dimensions of an object is zero, then the object does not exist. For example:
If a square has 0 depth, it can't exist in the real world, or can't be built because even a atom has 3 dimensions. The same applies to time, because if a tridimensional object exists for 0 seconds, than it never existed.
(all above is what I understood, correct me if I'm wrong)
But what I really want to ask is:
If nothing can exist or be built in less than 3+1 dimensions, does that mean every object in the universe must occupy some space on all the other dimensions that exist?
For example, if our universe is described by 4+1 dimensions, and tesseracts can be real objects and be built somehow, then our bodies, cars, houses and anything we can build, must occupy some space on that fourth dimension, or they couldn't ever exist on our perceptible 3+1 dimensions. Because if the length of a body on the forth dimension was 0, it couldn't exist at all.
If that is true, than everything we see and touch must occupy some space on all other dimensions the universe has, even our own bodies. Does that mean there's a portion of our ourselves we can't see or perceive?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
May6-08, 10:46 AM   #2
Recognitions:
Gold Membership Gold Member
That is indeed one of the implications of higher dimensions. In most hyperdimensional models (M-Theory and the like), the higher dimensions are so sharply curved as to "close up" on themselves at scales too small to technically qualify as "existing," in the scientific sense. So, one could call these "virtual dimensions," just like virtual particles. If these extra dimensions do exist (and there is strong circumstantial evidence to support that they do), then all existing things must occupy them. In fact, even empty space must contain these extra dimensions.
May9-08, 01:54 AM   #3
How does this relate to the notions of extended extra dimensions? I've read that some theories don't require 'closed up' dimensions, that we might live on a 3 dimensional brane in a higher dimensional universe. Is this more than conjecture? How would we tell the difference between this and having all dimensions curled up?
May12-08, 10:53 PM   #4
Sometimes physical models (like those of quantum gravity) will be calculated in 2+1 dimensions for simplification.
May13-08, 12:21 AM   #5
Yes, I've seen that done. But the high level guys talk about multiple dimensions which may or may not be curled up. I just wonder how our universe would differ between the two. I will dig further ... just found out about ITunes courses on line, so I shall be getting smarter.
Thread Closed
Thread Tools
Similar Threads for: About the dimensions of the universe
Thread Forum Replies
Does a bounded universe require more dimensions? Cosmology 20
Dimensions/parallel universe questions General Physics 8
Origin of the Universe: Created Universe vs Cyclical Universe General Astronomy 9
Parallel Universe, 10 dimensions.... General Physics 36
9 Space Dimensions 2 Time Dimensions General Physics 7
