New Reply
Fnet = ma problem
Share Thread Thread Tools
May6-08, 12:51 PM   #1
Fnet = ma problem
Blocks A and B are sitting side by side (touching) on a horizontal surface. A constant horizontal force Fa is applied to block A, which pushes against block B with a 32.0 N force directed horizontally to the right. The same force Fa is applied to block B; now block A pushes on block B with a 16.0 N force directed horizontally to the left. The blocks have a combined mass of 30.0 kg.
(a) What is the magnitude of the acceleration of the blocks in figure (a)?
(b) What is the magnitude of the force Fa?
2. Relevant equations
Fnet = ma
3. The attempt at a solution
Part 1: Fa pushes on block A:
Block A has Fa pushing to the right, and block B pushing to the left so
Fnet = massblockA *acceleration = Fa - 32N
Block B pushes back on block A (only horizontal force on it)
Fnet = massblockB *acceleraton = 32N
mass blockA + massblockB = 30kg
Using these three equations I solved for Fa and got that Fa = 30kg*acceleration...
I thought that I could use the next set of data (Fa pushing on block B) to come up with another equation, then I could solve for Fa and acceleration, but the equations are exactly the same, so pretty useless.
Any help would be great, thanks!
(ps~ I sometimes have trouble with FBDs, so if something is wrong with how I laid out the forces, it would be great to know!)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
May6-08, 01:05 PM   #2
Mentor
Quote by A_lilah View Post
They aren't exactly the same. Write an equation for the force on block A using the second set of data.
May6-08, 01:13 PM   #3
Ok, Now I'm really not so sure:
For Fa pusing on block A:
massA + massB = 30kg
so,
(Fa - 32)/ acceleration = massA
32/acceleration = mass B
(Fa - 32) + 32 = 30 * acceleration
So Fa = 30 * acceleration
For Fa pusing on B:
massA = 16N / acceleration
masB = (Fa -16) / acceleration
16N + (Fa - 16) = 30 * acceleration
or, Fa = 30 * acceleration
.... am I having a math problem then?
May6-08, 01:20 PM   #4
Mentor
Fnet = ma problem
so,
For Fa pusing on B:
Combine the two equations I highlighted.
May6-08, 01:25 PM   #5
Oh.... how did you know to use those equations? (I have a final coming up, and any tips would be great)
Thanks for your help!
May6-08, 01:44 PM   #6
Mentor
To me, those two equations are the most direct mathematical statements of the given data:
That tells me that: 32.0 = massB*a
From Newton's 3rd law, I immediately know the force on block A is 16.0 N.
That tells me that: 16.0 = massA*a
Add those equations to get:
32 + 16 = (massA + massB)*a
Then apply:
To get the acceleration.
The best thing to do is to write clear FBD diagrams of both blocks for both sets of data. Write all the equations and look for any easy ways to combine them.
May6-08, 02:06 PM   #7
Thanks for your help :)
Sep29-11, 02:57 AM   #8
Quote by Doc Al View Post
Sorry if I bring it up, but I have the same problem, and I'm trying to figure out how to solve it. I read all the post above, and one thing I don't understand is, the acceleration in those 2 figures should be different, they can't be the same, and if they're not the same, how can we set up the equations ?
Sep29-11, 03:22 AM   #9
unloved .... did you draw FBD ?
EDIT:first assume that the acceleration is different in two cases, when you set up equations , you will see that they turn out to be same
Sep29-11, 04:10 AM   #10
Mentor
Quote by theunloved View Post
Why do you think the accelerations of the two blocks are different? They are in constant contact.
New Reply
Thread Tools
Similar Threads for: Fnet = ma problem
Thread Forum Replies
Fnet and Force. Introductory Physics Homework 1
[SOLVED] What is Fnet? Introductory Physics Homework 6
Fnet Problems Introductory Physics Homework 1
Fnet Acceleration Problem Introductory Physics Homework 14
Fnet Question Introductory Physics Homework 3
