| Thread Closed |
Calculating Seal Temperature |
Share Thread | Thread Tools |
| May6-08, 02:08 PM | #1 |
Is there an formula to calculate temperature on a seal if rpm, pressure, time and coefficient of friction are known? Thank you.
Sincerely The TallOne |
| May6-08, 06:09 PM | #2 |
Hi tall one. You can apply basic principals here. Do you know how to determine frictional force between the seal and shaft? Frictional force times distance is work. Work per unit time is power (ie: heat which must be disipated). Once you have heat load, you need to figure out how that heat is being rejected. Either through simple conduction or convection or perhaps there's a fluid that's flowing past the seal that can carry that heat away. Hope that helps.
| May6-08, 06:44 PM | #3 |
Thanks! I'll give it try.
BTW - this site is cool! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculating Seal Temperature
| Force applied: calculating increase in temperature (work mostly done, need help!) | Introductory Physics Homework | 1 | ||
| calculating temperature using NTC thermistor | Electrical Engineering | 3 | ||
| Calculating pressure change with temperature? | Introductory Physics Homework | 1 | ||
| Calculating differential pressure across a seal | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Whaaa! Calculating the temperature of the suns surface! | Introductory Physics Homework | 1 | ||
