Physical meaning of minus in Faraday's law of induction
The discussion revolves around the physical meaning of the minus sign in Faraday's law of induction, specifically in the context of induced electromotive force (emf) and its directionality. Participants explore theoretical interpretations and practical implications of the law, including its relationship with Lenz's Law.
  • One participant expresses confusion regarding the meaning of the minus sign in Faraday's law, questioning how induced emf can be positive or negative based on changes in magnetic flux.
  • Another participant suggests using the right hand rule to interpret the direction of the induced emf, explaining that the sign indicates whether the emf is counterclockwise or clockwise based on the defined magnetic flux direction.
  • A different participant reflects on the broader confusion surrounding Faraday's law, mentioning the energy conversion in the context of a coil and magnetic forces, and raises a point about the independence of levitation height in the Meissner effect demonstration.
  • One participant views the minus sign as a reminder to apply Lenz's Law when calculating induced emf.
  • A later reply indicates that defining a reference direction is essential for understanding the meaning of the minus sign in this context.
Participants express varying levels of understanding regarding the minus sign, with some agreeing on the necessity of defining a reference direction, while others remain confused about the implications of the sign in practical scenarios. The discussion does not reach a consensus on the interpretation of the minus sign.
Participants mention different interpretations and applications of Faraday's law, highlighting the dependence on definitions and reference directions. Some points raised remain unresolved, particularly regarding the broader implications of the law in specific scenarios.
yoran
Hi,
I'm having some troubles with Faraday's law of induction:
[tex]\mathcal{E} = - {{d\Phi_B} \over dt}[/tex]
I don't understand the meaning of the minus. I do understand that, according to the law of Lenz, the induced current is directed such that it counters the change in magnetic flux. But I don't see how the induced emf can have a direction (positive or negative) because if the magnetic flux is increasing, the induced emf is negative and when the magnetic flux is decreasing, the induced emf is positive. But in a circuit where there is an induced emf, what is the physical meaning of a negative or positive emf?
Thank you.
right hand rule
To interpret the minus sign, use the right hand rule. Here's an example. Imagine a circular loop in the x-y plan and centered at the origin. Let's say we define the flux to be positive when the B field is pointing in the +z direction. If Faraday's law tells you that the sign of the EMF is positive, the right hand rule* will tell you that the EMF is counterclockwise (as viewed from the +z axis looked down towards the origin); if negative, then clockwise.
*If the thumb of your right hand points parallel or anti-parallel to +z axis (depending upon the sign of the EMF given by Faraday's law), the curl of your fingers will give you the orientation of the EMF.
Make sense?
Faraday's law of induction itself is confusing to me. Consider that the force x distance energy of pushing a coil against magnetism; converts to magnetic energy in the coil.
Force x distance relationships are independent of rate of movement through the force. Consider that in a demonstration related to the Meissner effect, a magnet placed above a superconductor is levitated. I suspect the levitation height is independent of magnet velocity before levitation.
I just think of the minus sign as a reminder to apply Lenz's Law when dealing with an induced emf.
Thanks guys I understand it now. So basically you have to define a reference direction in order to give a meaning to the minus sign.
Yeah, that seems right.
  • · Replies 27 ·
  • · Replies 25 ·
