Concussive effects of asteroid impact on marine life
The discussion focuses on the concussive effects of asteroid impacts on marine life, emphasizing that sound travels more effectively in water than in air. The user highlights a lack of research specifically addressing the acoustic impacts of large asteroid impacts, such as the Chicxulub and Wilkes Land craters, on marine ecosystems. Existing literature primarily addresses land impacts, with notable references including Ormo and Miyamoto's 2002 study on marine impacts and the University of Arizona's impact simulator from 2005, which lacks detailed marine acoustics analysis.
  • Understanding of asteroid impact mechanics
  • Familiarity with marine acoustics
  • Knowledge of the Chicxulub and Wilkes Land craters
  • Basic principles of fluid dynamics in relation to sound propagation
  • Research the acoustic effects of underwater explosions
  • Explore the implications of marine impacts on ecosystems
  • Investigate the methodologies used in Ormo and Miyamoto's 2002 study
  • Examine the University of Arizona's impact simulator and its limitations regarding marine impacts
Marine biologists, geologists, and researchers studying the effects of asteroid impacts on oceanic ecosystems will benefit from this discussion.
B. Elliott
I was doing some reading on the effects of air blasts from asteroid impacts when I realized that I've never seen any data of the potential effect on marine life. Since sound travels farther and faster in a liquid, wouldn't an asteroid impact in a large ocean (liquid) have a more profound concussive effect than it's gas counterpart?
I've been searching for the past couple of hours to no avail. The terms I'm using seem to be too generic and all I keep running across are the gas effects.
Referring more to larger scale impacts such as the Chicxulub and Wilkes Land crater in Antarctica. Asteroids approximately 5mi in diameter and up.
So far I've found a few semi-related sources, but still nothing that deals directly with the acoustics. I've found numerous papers on impacts in shallow marine bodies, but each paper states that the effect is still treated as a typical land impact. The latest sources I've been able to find are no later than 2002 which is now six years old.
Closest related sources yet...
Ormo, J., Miyamoto, H., Computer modelling of the water resurge at a marine impact: the Lockne crater, Sweden, Deep Sea Research II, v.49, p.983-994. 2002.
Large waves caused by oceanic impacts of meteorites
http://www.springerlink.com/content/hk743j629818n31q/
Even the University of Arizona's impact simulator writeup (2005) states that they did not spend a great deal of time incorporating marine impact effects due to the complexity of the calculations. The sources they stated for reference with marine impacts only deals directly with the cratering it's self where one ref. actually goes out on a limb and calculates the possible wave/tsunamis that could be generated. Again, no acoustics while the land-impacts receive quite a bit of treatment...
"Effect of a Water Layer" p.831-832
http://www.lpl.arizona.edu/~marcus/CollinsEtAl2005.pdf
  • · Replies 21 ·
  • · Replies 89 ·
39K
  • · Replies 73 ·
18K
  • · Replies 186 ·
97K
