Where Can I Find a Suitable 12 Wheel Rim for My Vehicle?
  • Thread starter Thread starter shanghai123
    Suggestion Wheel
The discussion revolves around finding a suitable 12-inch wheel rim for a vehicle, focusing on specifications and sourcing options. Participants share advice on measurement and potential suppliers, including both new and used options.
  • One participant urgently seeks suggestions for an OEM 12-inch wheel rim that fits their vehicle specifications.
  • Another participant advises measuring the bolt pattern and hub size before shopping, suggesting that scrap yards and tire shops are viable sources.
  • A repeated request for OEM suggestions emphasizes the urgency and need for specific recommendations.
  • It is proposed that visiting a local supplier with the hub for accurate measurements can help avoid errors in selecting the correct rim.
  • A later reply acknowledges the advice about visiting suppliers to mitigate measurement errors.
Participants generally agree on the importance of accurate measurements and suggest similar sourcing strategies, but there is no consensus on specific OEM recommendations.
Some assumptions about the vehicle's specifications and the availability of local suppliers are not explicitly stated, which may affect the applicability of the advice given.
Individuals preparing to purchase 12-inch wheel rims for vehicles, particularly those uncertain about specifications or sourcing options.
shanghai123
Suggestion For 12" Wheel Rim
I Need To Urgently Require To Buy A 12 Inch Wheel Rim For A Vehicle I Am Preparing...cud Anyone Suggest An Oem Which Has A Specification Suitable To Mine
All that you have to do is measure your bolt pattern and hub size, then go shopping at the scrap yards. If you want a new one, any tire shop will help you. You can also check out on-line catalogues by visiting rim manufacturer websites such as Cragar.
Assuming you are a bit uncertain working out the stud pattern and if your preferred supplier is local go for a visit and take the hub with you. The supplier will be able to take all the measurements needed and this way you will get the right rims.
Good advice, Engineroom. It removes the possibility of measurement errors, which are all too easy to make. :approve:
11K
9K
  • · Replies 19 ·
