Thread Closed
TSOP IR receiver help.
Share Thread
May8-08, 05:13 AM   #1
well i m designing a simple circuit in which a bulb is turned on and off by a simple household remote control. Normal remote control gives IR of 38 khz so i m using TSOP 1738, there is also an alternative of HRM 3800. Well i m having a problem that neither of them r working. When i press the remote, it doesn't give any voltage change whereas i want at least 4-5volts. Can anyone help me with this by providing some circuit for TSOP which works properly or have any idea, plz share it with me.
PhysOrg.com engineering news on PhysOrg.com
>> Multiview 3-D photography made simple
>> Giant 3-D printed bugs shed light on insect anatomy
>> A microphone that listens with light
May8-08, 06:46 AM   #2
From the datasheet, it looks like the thing gives out pulses corresponding to the IR pulse train from the zapper.
You may need additional circuitry to achieve what you require.
May8-08, 11:19 AM   #3
Mentor
Quote by Realhotshady View Post
Post some oscilloscope waveform pictures and your schematic, so that we can be of help.
May8-08, 07:25 PM   #4
i've posted the complete circuit. Everything is working well except the TSOP part. the voltage doesn't change at all. what can i do now? is there any alternative or is there any way i can connect the TSOP? i m using a normal tv remote control. plz help me out with this guys.
May9-08, 02:51 AM   #5
The other thing that just crossed what passes for my mind is that all zappers are not 38kHz...
Have you tried it with a different make of zapper?
May9-08, 03:42 AM   #6
Quote by zeitghost View Post
zapper? u mean remote control? i've tried it with tv and vcd remotes but both didn't work at all. i've learned these remotes generally gives 38 khz. how can i test the frequency?
May9-08, 11:43 AM   #7
Mentor
When you trace the receive signal with an oscilloscope, what do you see? Monitor the TX signal at the remote control's IR LED to see what the 38kHz modulated TX signal looks like, and look for a similar signal at the output (collector) of T1 in the RX circuit. What do the waveforms look like?
May9-08, 03:10 PM   #8
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hmmm, The TSOP should strip the carrier and just put out the remote pulse train, if it works like similar devices. So the 100u cap should work as a peak detector and saturate T1 giving a single transition for any key press on the remote.
With a DC scope probe you should see a DC transition plus a bit of a triangle wave at the output of the TSOP.
Any chance you simply miss wired the tsop?
The pinout is different from the schematic layout as the center pin does not go to t1 base.
May9-08, 08:43 PM   #9
i've seen this datasheet and connected the pin as mentioned here. but still its not working. i'v not yet checked the frequency with oscilloscope which i'll do later when i've the access to oscilloscope. what will i do next?
May9-08, 09:47 PM   #10
Recognitions:
Looking at the pdf and schematic, you should have 4-5 volts at the output of the TSOP with no remote input.
It should go to zero when triggered by the remote.
You can measure this with a DVM.
Your original post implies that the voltage you have is 0 always.
If this is so then you have a bad component in the circuit.
Thread Closed
Similar discussions for: TSOP IR receiver help.
Thread Forum Replies
A transmitter and a receiver Introductory Physics Homework 6
FM Radio Receiver Engineering Systems & Design 6
Building a VHF receiver 108-136 Mhz Electrical Engineering 31
TSOP 1738 38KHz IR Receiver Electrical Engineering 1
Digital Receiver Computing & Technology 0
